thebudman
Reno, NV
Question: is there anyhting wrong with using a 25', 12 gauge extension cord to hook up shore power to my TH for the purpose of only charging the batteries? My TH needs to be about 10 feet closer to the power source, and rather than move it, I was wondering if I could use the extension cord to connect the existing power cord to the outlet in my garage.
And, if I can use the extension cord to charge only the batteries, what about turning on the fridge? I would like to get it to cool down before we roll this weekend, and the TH is level where it sits. So again, I would like to leave the TH where it sits and use the extension cord. Would this cause any problems, or am I flirtin' with disaster? The specs on the cord, for what it's worth, read SJTW, 12/3C, 15 amps, 125V, 1875W.
08 Dodge Ram 3500 Mega Cab 6 sp manual
08 WW FK 2100
08 Rhino
99 Honda TRX 400
08 Yamaha TT50
9-11: Never Forget!!!
If you have the urge to fly your country's flag, then go do it on your native soil.
jackxclan
bakersfield
I have a ext. cord hooked to mine all the time, it charges, runs the frige and the the A/C if needed. Its prolly a 12 guage not huge but not a typical smaller cord.
Gun metal gray 07 new body style 3500 diesel crew cab 4x4 dually
red WW fsc 28 tiki hauler
red 400 ex
black 250ex
red 400ex
red 250ex
red KW heavy iron hauler
HOOLIGAN # 385
RE_Todd
Lemoore, CA, USA
I use a 75 footer to charge my batteries and cool down the fridge, no issues.
TinBenders
Formula Toy #006
2007 Can-Am 500 MAX XT
2009 Eclipse Attitude F37 AKS, it's still not white!!
08 F350, $X$, CC, dually.
jim87vette
Arizona
Should work fine.
08 GMC 3500 Dually Duramax
96 Chevy 2500 6.5
05 Yamaha Rhino
04 Gearbox 335FS 5er 14k wet
DuneJunkie
Rohnert Park, CA.
You shouldn't have any problems......many of us do the same thing.
2005 Chevy 2500HD 4x4 CC Duramax/Allison, with 18K SuperGlide Hitch
2008 385 Fleetwood Gearbox
2005 Yamaha YFZ 450
2002 Honda 400ex
davidj54
South Alabama
I use a 25' 12ga cord and sometimes I even run my A/C. The biggest problem I have had are the cheap built 30a to 15a adapter plugs. They will melt if I run the A/C too long. I have to watch them. I've replaced three of them so far. One day I'm going to make a good adapter that won't be a problem.
Dodge Ram 2500 Mega Cab (Yeah, it's got a Cummins)
2006 Forest River Grand Surveyor GS-280
Prodigy Brake Controller
1000/10000lb Equal-i-zer with 4-way sway control
Polishnurse
Schodack, NY
Yes.
MCrankyPants
Dayton OH USA
At 25', you're totally fine, I stick to 10 gauge for anything longer.
2007 Teton Experience Sunrise pulled by 2003 Dodge 3500 Cummins HO 6-spd. 4x4
'61 VW Double-Cab
Y-Guy
Tri-Cities, WA
Something to consider is buying a 30amp extension cord. I bought one when I used a generator I left in the bed of my truck. I use it now to hook up to the house, even if I am only using 15/20amp there is less loss on the line. You are fine using an extension cord though, I do that too when I need to charge the batteries and run the fridge. Just avoid using the high draw appliances like the microwave or AC.
Forced Family Fun... They'll thank you later for it!
Have you checked out the new RV.net Blogs?
thebudman
Reno, NV
Thanks for the responses. I will go plug it in and proceed to get the beer-- er-- water and juice for the kids-- cold.
