RV.Net Open Roads Forum: Tow Vehicles: Rear Differential Question for F-150 Owners
Search only in Tow Vehicles
 > Rear Differential Question for F-150 Owners
krazymatt
NM
Posted: 07/30/08 09:38am Link  |  Quote  |  Print  |  Notify Moderator
I was noticing as I pulled into my garage the other night when my car's headlights shined on my truck that there seems to be a wet area on the rear diff kinda where the pumpkin meets the left axle housing towards the top , perhaps from a vent? Also I had the truck serviced at the Ford Quicklane the other day and maybe they topped it off and spilled some oil. Any other similar experiences? I've been using it to tow my camper, I hope there's not an issue with the rear end. Thanks
BTW, it's a 3:73 Rear non-limited slip. Truck details in signature.
New Mexico
2008 Forest River Puma 26RLSS
2008 Dodge 2500 SLT Big Horn QC Cummins 4x4 6Spd Auto, Exhaust Brake.
Easy-Lift 1000 WD hitch.
2400IS Yamaha Generator
labman1014
hattiesburg, ms
Posted: 07/30/08 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
i would get under it to see exactly where it is coming from. could be the pinion seal and it runs down the housing to that side. or it could be what you said. would know til you know where it is coming from...
TV-2008 Ford F150 SCrew, 4X4, 5.4L, 3.73LS, Rear Camera
TT-2008 Surveyor SV-304LE
Just me, the wife, 3.5 year old, and 10 month old!!!
no_bytes
Wisconsin
Posted: 07/30/08 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same thing, bring it in. I believe mine was a seal (can't recall inner/outer whatever), it shouldn't be too big of a repair bill, I don't believe mine was.
stympy
Connecticut
Posted: 07/30/08 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
I just had my pinion seal replaces after 27000 miles. My differential was pretty wet from the slinging of the oil.
2006 F150
Wife and Myself
3 Boys & 2 Girls
Cocker Spaniel JJ
krazymatt
NM
Posted: 07/30/08 10:54pm Link  |  Quote  |  Print  |  Notify Moderator
I got underneath, and it is right where the pumpkin attaches to the rest of the axle housing. There appears to be some sort of pin that holds the pumpkin and the axle housing together. Who knows? I wonder if towing my 7500lb-8000lb loaded 26' Puma had anything to do with it?
krazymatt
NM
Posted: 07/30/08 10:58pm Link  |  Quote  |  Print  |  Notify Moderator
Oh, and one more thing, I checked that diff oil level, and Those Bastards at the quicklane didn't even check the rear diff oil. It was obvious the plug had never been removed and the oil is a tad bit low. I knew there was a reason I always change my own oil! Multi-Point inspection my A$$!!!
Dave H M
IL
Posted: 07/31/08 07:16am Link  |  Quote  |  Print  |  Notify Moderator
krazy
myself, I would just watch and see if develops further. As long as it is not forming a drip that is.
krazymatt
NM
Posted: 07/31/08 08:05am Link  |  Quote  |  Print  |  Notify Moderator
Considering it's still on warranty, I'll probably just take it in next week and have them look at it. As long as they don't use the famous "it's normal" line because I swear I'll strangle the service advisor.
