RV.Net Open Roads Forum: Tech Issues: Can't cool motorhome
 > Can't cool motorhome
ejforwood
Littleton (Denver) Colorado
Posted: 07/31/08 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
Scoundrel wrote:
Whats wrong with 85deg's during the day? run around outside for a couple of minutes in the 100+ heat and when you go back into the coach it will feel cool..
More importantly what is the temp at night......Night time temp's are more important I would think...
Agreed!
Who goes to Vegas to sit inside the MH when there is "Air conditioned Vegas" to see and do!
Jerry, Dottie & Chan, "the little furry one"
98 Bounder 34V, 99 F-53 Ford V10 chassis
06 Saturn VUE 4I
MrWizard
Van Nuys, Ca
Posted: 07/31/08 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Ritterbach1 wrote:
Have a 2006 40' Allegro Bus with two 15,000 Norcold A/C's. Front has switch to allow air to bypass ducts, bedroom does not. Sitting in Nevada in 100+ heat we can't get it below 85deg during the day.
Camping world checked them out and both seem to be working OK.
Have awnings out, front blocked with foil screen and curtains.
HOT HOT HOT
Any help on changing brands? These are norcold.
HELP!!!
slides are a (1) point
another important point, this is ODD fixation of dark even black paint jobs even on the roof,
with A/C covers even painted gray or black
this adsorbs a lot of heat that is next to impossible to remove or stop
if this is your coach, the A/C's are working them selves to death
paint the roof white, and get new a/c covers or paint them white
I don't know why MFG's ever started using this paint scheme, especially on the roof, where it hurts cooling efficiency and nobody can see the matching roof paint/graphics
BTW.. this has been brought up before..
so get more A/C units or paint the roof white with 'rubber coating'
Connected via Verizon Via LG Dare VX9700
Maximum memory has been reached !
Ritterbach1
Hayden, Idaho
Posted: 07/31/08 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Well, Moving to cooler climate might make sense...but going outside in 100 deg heat...then 85 does not seem hot? LOL I know this must be a joke!
Washboy
Denver, CO
Posted: 07/31/08 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
flhtci-rider wrote:
the intake and the exhaust chambers must be completely sealed from each other. Turn off the unit. remove the 18" sq cover completely. Now feel up inside with your fingers and see if U can go from 1 side o the other. If yes U need to buy that alum tape at home hardware and seal the 2 chambers. In a really high heat / humid this can cause dripping. this problem is in 70% of all coaches
Agreed! I suffered with high temps in LV during my first summer stay. I found serious air leaks inside the ceiling unit...cold air was being sucked into the warm air inlet. I sealed the two chambers and added a 2nd A/C unit over the bedroom. Results? I can now keep the coach at 72 degrees, even when parked at Circus-Circus with 100 degree daytime heat.
"If you don't know where you're going, any road will get you there."
2003 GMC Sierra SLT ExtCab 3500 D/A 4X4
2003 Carriage Cameo LXI F34CK3
Scoundrel
Corona, Calif. USA
Posted: 08/01/08 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
stevelv wrote:
If you think that's hot - try going to India during the Summer - 125 degrees with 95 percent humity - after 30 minutes you are as miserable as you have ever felt and then you are surrounded by a million people who have no concept of 'personal space', so you are jostled and pushed by everyone. You are then choked by the traffic fumes and polution.
Are you sure you haven't died and gone to......well you know
2004 Forest River Georgetown 346
2000 Harley Davidson Dyna.
FMCA 389346
“Some people are like slinkies......
Not really good for anything, but they will still bring a smile to your face when you push them down the stairs.
Don & Lucy
Bob Landry
Austin, texas
Posted: 08/01/08 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
ejforwood wrote:
The normal range for RV air conditioners is to only be able to cool the outgoing air 20 to 25 degrees lower than the incoming air and you are sitting in a box that is well heated by the 110 degree plus Vegas air.
Your air conditioner is not drawing air in from the outside. The 20 degree split you are looking for is the temperature diffence between the discharge air fron the unit and the return air from the interior space being drawn back across the coil..Often refered to as the split across the coil..
Bob Landry
Austin, texas
Posted: 08/01/08 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
A piece of equipment needs to work correctly, day or night, and it's either right or it's not.. Period..
Techie
Pahrump, NV, USA
Posted: 08/02/08 08:40am Link  |  Quote  |  Print  |  Notify Moderator
We spend a lot of time in Pahrump (no shade) and 100+ outside in the summer is normal. In fact just returned from there so I can feel your pain.
We have 2 AC's and can keep the interior temps down to about 78 or so. What we do is all of the obvious stuff (exterior screens on the windshield and front side mirrors, awnings out, roof cleaned, etc) but more importantly we get the rig cooled off early. After breakfast we'll set the front ac to 75 and the rear to 72. Since the rear is the same size unit but a smaller space it can cool that area down more easily than the front which has a large space to cool. We then run a small fan on the ground to move the cooler air from the rear to the front and then a fan in the front on the dash just to help circultae the air even more.
The reason we go through all of this is that we often need to work during the day in the rig. We generate plenty of heat between the computers and the DVR plus all of the normal stuff.
BTW, once we get to the evening we usually set both acs to 75 and turn the small fans off.
Also, when its not too windy putting out the big awning helps a lot.
I know that if we closed the big front slides that woudl help but since we have to work inside that isn't an option.
2006 CC Allure 40' Quad Slides Tag Axle Cummins 400
2004 Honda Element EX/AWD Toad; Blue Ox Aventa II/USGear
MS S&P/EVDO
FMCA
