RV.Net Open Roads Forum: Beginning RVing: Leveling a C class
 > Leveling a C class
Artie322
New Jersey
Posted: 07/30/08 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
What is the best method of raising the front end of a class C MH to level it? Do you have raise both sides, or can you raise only one side if the "bubble" is showing low spot, say, right front?
* This post was edited 07/30/08 06:15pm by Artie322 *
Reggie
Doug and Cassi Glass
Clifton Forge, VA
Posted: 07/30/08 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
Pieces of lumber or the plastic blocks like big LEGOS sold at Wal-Mart and Camping World.
dobbler98
Ohio
Posted: 07/30/08 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
We have a hydraulic bottle jack for lifting and carry a few blocks of wood to put under the tires or tripod stands to level. I have been thinking about getting two of the crank-style scissor jacks to try tho.
1993 Minnie Winnie
Class C 24'
Chevy 350
Usually pulling one of my toys
CloudDriver
New Jersey Shore
Posted: 07/30/08 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
To answer your question, yes you can block under only one front wheel if that is all that is needed to get level.
The Michelin RV Tire Guide has good info on the proper procedures for using blocking.
2003 Winnebago Minnie 24F - Ford E-450
rockhillmanor
On the Road
Posted: 07/30/08 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
You can raise any combo. One tire, two tires whatever you need to level. Only rule is if you have to raise the back end, blocks have to be under both duals on that side.
The fastest, easiest, and lightweight to carry are leveling blocks.
They can be found at any Camping World store and at all RV dealers parts deparment.
http://www.campingworld.com/shopping/product/rv-leveling-blocks/4155
Happy Camping!
rock
31 ft Four Winds
Chevy Tracker 4x4 Blue Ox
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
rockhillmanor
On the Road
Posted: 07/30/08 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
which link on the site is the blocking info? tks
Nick Wildwood
Hell California
Posted: 07/30/08 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
We use the 2x6's or 4x6's cut in a wedge shape. If we get into any kind of survival situation we can always use them for a fire. We thought about the trailer type of scissor jacks but couldn't find any tall enough.
Bumpyroad
Virginia
Posted: 07/31/08 05:22am Link  |  Quote  |  Print  |  Notify Moderator
Happy Camping!
rock
these look wider than the red ones I have. the red ones are NOT wide enough to support the side walls of my Class A tires. it looks like these might be.
bumpy
Artie322
New Jersey
Here's the problem. I was at a campsite and placed the leveling blocks under one front wheel. Checked the bubble level -no change. Backed off, kept adding one level at a time until I reached the max recommended and there was still no significant change in the bubble level.
Rather frustrated, I walked down to place the permit in the holder and when I turned around what I saw was the wheel on the levelers pushed way up into the wheel well, which did not look at all healthy to me, but it certainly explained why there was no significant change in the location of the bubble.
I backed off and wound up moving the vehicle until it was at a diagonal on the pad (part asphalt, part gravel) which ended up being a lot closer to level than using the leveling blocks.
It was fortunate that in this particular situation I had enough room to maneuver, but if I find myself in a similar "skewed" situation I'd like to know how to resolve it.
Bobbo
Memphis, TN
Posted: 07/31/08 08:52am Link  |  Quote  |  Print  |  Notify Moderator
That sounds like a suspension problem to me.
Bobbo, Linda and the furry kid (German Shepherd)
'07 Winnebago Outlook 31C on a Ford E450 Super Duty Chassis
NRA Life Member
Near N35 12 17 W89 50 57
