RV.Net Open Roads Forum: Class A Motorhomes: watch rv amps
 > watch rv amps
Page of 5
helperzack
Port St. Lucie, FL
Posted: 07/30/08 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like you have several good suggestions here. The forums are great for learning.
Can you post for all here the dealer that didn't educate/explain this to you?
I know on our MH, which is our first RV, the dealer explained EVERY thing. Well, I think we spent about 10-12 hours total in it before we even made the offer. So we had tons of questions.
Also post what you do to correct your situation, so others who follow will learn. Thanks for the post.
’07 Coachmen Mirada 310DS
Counting my blessings with my high school sweetheart.
3 kids, 39 foster kids(not all at once) 2 boys currently
Do you have room for a child? Consider fostering/adopting a child. Thousands of children are in need of a loving family.
avidude
Posted: 07/30/08 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
morganhillers wrote:
Just an FYI that my new Fiesta has two A/C units and 30 amp shore power hook-up. Generator is 50 Amp. The 30 Amp does allow both A/C units to run and cool the coach. If I run something else that pulls a lot of current (e.g. blow dryer) the energy management will shut off the fridge first (switches over to gas), then zone 2 (bedroom) air, then zone 1 air. I haven't had the coach too long, but so far have only seen it shut off power to the fridge when on 30 amp. I rarely go to a campground with 50amp, so I actually like this feature.
Just goes to show the a similar priced Fleetwood is just better engineered. In fact, my 1998 Fleetwood Pace Arrow had the same EMS system that allowed both AC's on 30 amp service - 10 years ago.
To many manufacturers are cutting too many corners these days.
Ted
'07 Bounder Diesel 38S
Cat C7 300hp, Allison 3000MH
Tow: '06 GMC Yukon
Gale Hawkins
Murray, KY
Posted: 07/30/08 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
They have to dumb down something to make it easier for the salesman to upsale from a lower end unit. There was no real cost savings when building the unit.
Hyall
Davie, Florida
Posted: 07/30/08 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
I hope you don't take alot of this stuff serious most of it @@@@@@@
You have a good rig just work it out
2007 Gulfstream TourMaster T40B MBE 926
2007 Honda CR-V
MC Honda VTX 1300R grey is faster
MC Shadow Aero 750 wife's
DON'T WORRY ABOUT NOTTIN - NOTTIN IS ALRIGHT
kd8wdave
Middletown,OH
Others have 'told you how it is', I will tell you , you have an easy fix. Like another poster said, split off the second A/C, but feed it with a three way switch (common at Lowes,Home Depot, any hardware store). Feed one side of the three way from genny, and the other with a #14 or #12 SO cord (also at named locations). When you hook up at the CG, just connect the extra cable and put the three way swith to feed from the CG, when on the road, throw the switch the other way to feed from the genny. No danger and its safe that way.
JMHO
cheers
emmmw
Virginia
Posted: 07/30/08 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Our coach is only 30 amps and we don't have any issues with powering both A/Cs and numerous other items simultaneously (except for my DW's hair dryer). The EMS does a great job and is not noticable at all when things shut off and turn on.
miket
Southwick, Ma
Posted: 07/30/08 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
My coach draws 20 amps with both roof AC's on, 13.5K BTU front, 11K BTU rear. My EMS will back off the electric water heater, rear AC compressor, rear fan and Fridge if necessary to keep under 30 Amp draw.
Mike T
2005 Winnebago Voyage 33V, Workhorse W20, with '06 CR-V in tow, SMI 4 wire Braking system, Blue Ox Underskirt, Pressure Pro.
FrankReno
Reno, NV
Posted: 07/30/08 11:02pm Link  |  Quote  |  Print  |  Notify Moderator
Solved our problem for about $100. .
http://www.psrv.net
It also provides backup if one breaker blows in the park, Love it!
Good luck!
Frank & Marion
2004 Southwind 36B
Workhorse W22
Little Green Jeep Toad
Driver Jake The Wonder Dog
Copilot Chip the Pup
Gale Hawkins
Murray, KY
Posted: 07/30/08 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
Frank I read all of the info but still not sure why this is needed?
It seems just running a 12/3 120 volt cord from the CG hook up to a male connect to the 2nd A/C unit would be more simple.
Bumpyroad
Virginia
Posted: 07/31/08 05:08am Link  |  Quote  |  Print  |  Notify Moderator
chastho wrote:
I thought it was common knowledge that you need 50 amp to run two a/cs.
I didn't know that since I can run two on my 30 amp winnie with EMS. but if youze buys cheap, you gets cheap. JMHO
bumpy
Page of 5
 > watch rv amps
