David_in_TX
Grand Prairie, Texas
They are naming it the Super Max:
http://www.gulfstreamrv.com/09/63111.htm
Camping Dutchman
NJ
whats the weight on that one? I would say that has a low CCC. More of a 4500 chassis than a 5500 chassis if comparing to Chevy.
2008 Chevy 3500 cc DRW Duramax
2009 Cedar Creek Silverback
2004 United Specialties Sold
Member:Good Sam Club Haulin Highlanders
ronfisherman
SE Michigan
Camping Dutchman wrote: whats the weight on that one? I would say that has a low CCC. More of a 4500 chassis than a 5500 chassis if comparing to Chevy.
The model is the same as our Endura (except bunks). Better be a 5500 or there is no CCC.
Saf-TTE tire monitor
goodwind
Arkansas
You better stay away from Gulfstream !!!!!!!!!!!!!! They are a pitiful company with no care for building quality coaches and their plant looks like it has not been cleaned in years>
Camping Dutchman
NJ
Some specs from sterling site. Called the Bullet truck
Regular Quad Cab
Powertrain Standard: 2WD 2WD
Options: 4WD
4WD
BBC Standard: 123" 143"
GVWR Standard: 16,000-19,500 lbs 16,000-19,500 lbs
GCWR Standard: 26,000 lbs 26,000 lbs
Wheelbase/CA Standard: 144.5" / 60" 164.5" / 60"
Options: 168.5" / 84"
192.5" / 108"
204.5" / 120"
188.5" / 84"
Engine Standard: Cummins 6.7L ISB
305 hp
610 lbs-ft torque Cummins 6.7L ISB
305 hp
610 lbs-ft torque
Manual Trans Standard: MB G56 6-speed MB G56 6-speed
Automatic Trans Standard: AS68RC 6-speed AS68RC 6-speed
Axle Ratios Standard: 4.10 4.10
Options: 4.44
4.88
4.44
4.88
Front Axle Standard: 7,000 lbs 7,000 lbs
Rear Axle Standard: 13,500 lbs 13,500 lbs
Front Suspension Standard: 7,000 lbs 7,000 lbs
Rear Suspension Standard: 12,000-13,500 lbs 12,000-13,500 lbs
Frame (section modulus) Standard: 50,000 psi 50,000 psi
Fuel Tank Standard: 52 gal (rear) 52 gal (rear)
Options: 22 gal (midship)
22 gal (midship)
PTO Prep Standard: Standard Standard
Camping Dutchman
NJ
it's a class 4/5 truck according to them.
az99
N.Y.
Looks like this model will be short lived. Link
Camping Dutchman
NJ
Watch Gulf Stream buy up the remaining cab and chassis and keep going with it. Isn't the engine in the international they use discontinued also....
