RV.Net Open Roads Forum: Class A Motorhomes: 1997 Newmar Dutch Star 3865
 > 1997 Newmar Dutch Star 3865
wbrowning
Southeast Texas
Posted: 07/31/08 05:20am Link  |  Quote  |  Print  |  Notify Moderator
Is this a good unit it has 59000 miles with a 300hp cummins and 6 speed trans with one slide It hhas 700 watts diesel generator.
http://www.rvt.com/rvdetail3869048.htm
randco
Sarasota, Florida
Posted: 07/31/08 05:36am Link  |  Quote  |  Print  |  Notify Moderator
If it's in good shape that's a pretty darn good price.
NADA Low Retail is $46,260
wolfe10
Posted: 07/31/08 06:47am Link  |  Quote  |  Print  |  Notify Moderator
Being located in Flint MI, be concerned about rust.
Have you looked at PPL much closer to your home-- they are in Houston. I was there last week on business and they had a LOT of DP's in that price range.
http://www.pplmotorhomes.com/diesel/diesel-motorhomes.htm
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
CurtisG
Vinton, Louisiana
Posted: 07/31/08 07:04am Link  |  Quote  |  Print  |  Notify Moderator
That's a very good price on a very good coach---wish I could find one close for that price. I was at PPL earlier this month but most diesels were higher priced---found a '94 Country Coach for $45,000 that had been well taken care of, most in that price range were not taken care of. I'm going back in a couple of weeks to look again in person because the online photos make them look better than they are.
Curt
sjholt
Henderson, NV
Posted: 07/31/08 07:59am Link  |  Quote  |  Print  |  Notify Moderator
If I was interested in this mohome- I would ask for some pictures of the chassis and if there is just light rust then I would invest in a ticket to fly there and look at it as it is an extremely good price.
I bought a 96 monaco that was in Mo. for all it's life and there was only light rust on some of the chassis that wasn't covered with undercoating.
Go for it and good luck.
Skip
1996 32' Monaco Windsor DP
Cummins 5.9L 230 HP
5 Airbags in front- 4 in back
TMitchell
Punta Gorda, Fl.
Posted: 07/31/08 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Looks like a great deal. For that good of a price, I would either fly or drive up there to check it out. Check the ceiling for any water stains. Unless the tires were changed recently, you should factor in the cost of 6 new ones. Climb up on the roof and check the caulking along the seams. Make sure you test all the equipment, air conditioners,furnace,refrigerator,hot water heater,generator,hydraulic jacks,etc.
Open and close every drawer door and window.
Ask to see the maintenance records.
You could put several thousand dollars in that DSDP, after you buy it and still be way ahead.
Tom
Tom,Pat and Buster the Boston Terrier
2004 Dutch Star 3807 Spartan 370HP
Jeep Grand Cherokee
boogaloo
Houston, TX
Posted: 07/31/08 09:06am Link  |  Quote  |  Print  |  Notify Moderator
I have not been inside one of these coaches but the description shows it has almost all of the features of a '97 40ft Holiday Rambler Navigator I bought in May for $88K. Same engine, transmission and similar layout for a much lower price. I think you found a good deal if it checks out mechically. Newmar seems to have a great reputation.
Best of luck to you.
Bumpyroad
Virginia
Posted: 07/31/08 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
wouldn't that have an 11 year old rubber roof?
bumpy
Deen
Vancouver, WA
Posted: 07/31/08 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
bumpy
Probably, our 2000 DSDP ha a fiberglass roof but as I remember 2000 was the first year that Brite Tek was offered so you're probably right.
The Brite Tek carries a 12 yr warranty, the fiberglass is one year.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
