RV.Net Open Roads Forum: Travel Trailers: Cracked Grey Tank
 > Cracked Grey Tank
txsharkbait
texas
Posted: 07/31/08 10:16am Link  |  Quote  |  Print  |  Notify Moderator
I have an 83 Funtime camper that developed a crack in the grey water tank.I am having a hard time locating a replacement.
I have looked online and talked to PPL and Camping World and a couple other smaller places.NO LUCK!!! I didnt think it would be a problem
Do any of you have a recomendation?
Thanks
Kevin
pmooney1
massachusetts
Posted: 07/31/08 10:49am Link  |  Quote  |  Print  |  Notify Moderator
Would some Eternabond tape click be able to fix the leak, or is the crack too large? This is a quote from a part of their web site
"Restore: Commercial roofs, RV roofs, Mobile home roofs, gutters; Repair leaks and holes in: All roofs - commercial or residential; all RV, mobile home, trailer roofs; all metal roofs; holding tanks; awnings; gutters; skylights; flashings; boats; pool and pond liners; tears in convertible roofs, tarps and tents; cracks in basement walls; boat, car, pool, and grill covers, etc.!"
2001 GMC Yukon 4x4 SLT
2007 Kodiak 30BHSL
Mike Day
Taftville, Connecticut
Posted: 07/31/08 11:08am Link  |  Quote  |  Print  |  Notify Moderator
Try this website.
Pellandent Enterprises
They have a lot of OEM RV stuff.
2005 Dodge Ram 1500 Quad Cab
Feetwood Wilderness 26T
Me, DW, and one Pug. All 3 are rookies at this camping stuff.
1995brave
San Antonio, TX
Posted: 07/31/08 11:56am Link  |  Quote  |  Print  |  Notify Moderator
Drill a small hole at the ends of the crack, rough up the area along the crack and holes, and then fill with a good two part epoxy or JB Weld.
rhondavid
Birmingham, Al
Posted: 07/31/08 11:57am Link  |  Quote  |  Print  |  Notify Moderator
According to DW you can fix anything with duct tape.
Wish I really had an answer for you but I don't
David,Wife,4 kids,SIL,1 grandchild
2003 Ford Excursion Eddie Bauer 7.3 PSD w/3.73 rear end
Jayco Kiwi Too 30T bunkhouse w/triple bunks
Prodigy Controller
Reese Dual Cam HP
Michelin LTX M/S
Topsail Hill Cult Member
JJBIRISH
Butler, PA, USA
Posted: 07/31/08 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
tanks
try here... they make a epoxy just for the tanks also...
Love my mass produced, entry level, built by Lazy American Workers, Hornet
taborekle
Clements, Md
Posted: 07/31/08 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
I would agree with the posts for epoxying. I would add either a fiberglass matt or roving to the mix. That will streangthen the entire area of the crack and give additional protection against leaking. You can find either matting or roving at either Boaters World or West Marine.
Wear gloves.
Larry
hilldude
Red house WV
Posted: 07/31/08 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Plastic can be welded have to use the same type of plastic the tank is made of.Harbor Freight may sell a weld kit.saw them weld liner for holding pond in chemical plant.
Hornet28BHDS
Parker, PA
Posted: 07/31/08 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
Eternabond or plastic welding will fix the leak.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
4BeachCampers
SoCal
Posted: 07/31/08 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
Your grey water tank isn't under anykind of pressure, Therefore you can use Mighty Putty to fix it!
1999 Starcraft 21CK
View our Profile for more pics...
 > Cracked Grey Tank
