RV.Net Open Roads Forum: Class B - Camping Van Conversions: B warm
505live
Albuquerque, NM
Posted: 07/31/08 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
Survey:
I'd like to get some heat in my DIY ghetto B without breaking the bank. I have been using a propane catalytic heater (Little Buddy, or as I call it, Little B@stard, scuse me..), but only when up (not run while sleeping). Does ok, but where I go anywhere I want heat is >5000' elevation and the little O2 sensor is soooo sensitive that when I need it most in the morning the darn thing won't lite, or stay lit. If I wasn't apposed to littering the thing would be in the bottom of a lake right now. I'd love an Eberspacher as the vehicle is diesel, but the price is out of the question for this machine.
midnightsadie
ohio
Posted: 07/31/08 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
for kicks I looked on e bay theres a couple , just type in eberspacher
mockturtle
Northwest
Posted: 07/31/08 11:14pm Link  |  Quote  |  Print  |  Notify Moderator
I think these are considered better: Olympian Wave Catalytic Heaters
Husband: Derek
Dog: Bucky
RV: 2000 Aerolite 19RB TT
TV: 1996 Chevrolet Blazer 6 cyl. 4WD
This car used to be our toad, now is our TV!
VernM
Marion County, AR
Posted: 07/31/08 11:34pm Link  |  Quote  |  Print  |  Notify Moderator
You don't say whether shore electricity is available. If it is, the oil-filled radiator-type electric heaters are unbeatable for small footprint, safety and quiet warmth in a space the size of a B.
VernM
GMC Conversion van/Wells Cargo MiniWagon trailer
Sent via HughesNet/SatMex5 Internet Portal
vikx
Washington State
Posted: 07/31/08 11:36pm Link  |  Quote  |  Print  |  Notify Moderator
I agree, the Olympian is safer, works better and doesn't fail at elevation. The Wave 3 should be fine for a smaller B.You can even sleep with it with a vent/window opening. (square inches required to vent the heater are in the instructions) VK
bananadanna
Cambridge, MA
Posted: 08/01/08 05:31am Link  |  Quote  |  Print  |  Notify Moderator
We had used a portable cat heater in our old unconverted Econoline pretty much the same way you do now.
There is simply no comparison to how much nicer the Airtronic D2 is in our DIY Sprinter. It is such a leap ahead of a conventional rv propane heater. Quieter, more btus per gallon, much gentler on the batteries. No oxygen consumption issues.
I did find an experienced installer who does this on the side and paid $250 to put it in for me. That was a good deal.
Pretty much all the major systems--the Prosine inverter, the Engel fridge, the Airtronic, micro, induction burner, even the bench system, were designed to be salvageable for the next diy camper if I don't get ten more years out of this one or the price I'd want "as is" when the time came to sell it. So I could justify using better components since mostly the labor costs would be the only completely lost cost.
If you can manage the diesel heater you won't regret it. We're able to drycamp when the nights start to get cold. Feels ridiculously luxurious to have 50-site campgrounds completely to ourselves.
Dan
02 Freightliner Sprinter 2500 long tall home brew conversion
505live
Albuquerque, NM
Posted: 08/01/08 08:06am Link  |  Quote  |  Print  |  Notify Moderator
VernM,
I keep forgetting to mention shower powered vs dry camping, for me it is almost entirely dry camping. Most of the stuff I go to in this thing (triathlons at lakes, mtn bike races, etc) are generally at pretty undeveloped areas, or are sufficiently popular that it would require an act of God / Congress to get a powered site. The only time I got a powered site it was b/c the dry camping sites were full, and I never thought I'd get a powered site so I didn't even have a battery charger with me...
mockturtle,
Thanks for the line on the Olympian Wave!
That's a very good point, I hadn't really considered it. This vehicle is sort of an experiment for me, seeing what I can do with home produced biodiesel and if a B is really something my wife and would make sufficient use of to justify. I suppose if later we're loving it so much that I upgrade to a new diesel Quigley 4x4 (ha!!) van I could always move the stuff over.
I'd be very curious if the Airtronic would operate on B100 or blends thereof.
bananadanna
Cambridge, MA
Posted: 08/01/08 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting question. The heater is very simple but the worst case of congealed fuel is where you would need it most. Could be reasonable to switch over to a regular winter-blend diesel for the coldest temps.
I did find the tech support very good. You might ask them.
diyvanner
Rhode Island
Posted: 08/01/08 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Completely agree with what Dan says about the Airtronic D2. I installed it myself and it’s a very straightforward procedure. In fact you could pick one up a used one, install it yourself, and even order any missing parts (I ordered the muffler later). I fully intend to keep mine “forever”
diyVanner
505live
Albuquerque, NM
Posted: 08/04/08 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
It (Airtronic) definitely sounds like the way to go. Just looking on eBay as previously suggested turns up a couple used ones that look interesting. What level do you find the D2 running at most of the time to keep things cozy? I don't know how they operate, so I was wondering if they use a fan that is powered by the expanding exhaust, basically like a turbo, to move the hot air? So, the only current draw is the fuel pump? If that's not how it works, forget I mentioned it, I'm gonna be rich! =)
Interestingly, I found a PDF data file:
http://ovniclub.free.fr/dossiers/chauffage/Chauffage_Eberspacher_Airtronic.pdf
It says that the D2 is not certified for biodiesel, but up to 10% blend is ok. The larger D4 *is* certified for biodiesel.
