RV.Net Open Roads Forum: Tech Issues: Moen Shower adjustment?
 > Moen Shower adjustment?
kalynzoo
Los Angeles , California
Posted: 07/31/08 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
My Winnebago Adventurer has a Moen single handle shower control. Recently the shower seems to have broken. When turned to hot, the water flow diminishes. There is plenty of volume at cold, but it is cold. I just took off the handle and there does not appear to be a cartridge, but perhaps the control setting has slipped. Has anyone else dealt with this problem? Hot water works fine at all other faucets.
Thanks, Gary
alpenliter
Olympia WA
Posted: 07/31/08 11:32pm Link  |  Quote  |  Print  |  Notify Moderator
Look inside the plastic handle Gary and see if part of the sleeve has broken off. This can cause erratic pressure and temperatures. If the handle is fine the problem is in the cartridge. If it is a single handle Moen product, there should be a small retaining clip that holds the shaft (where the handle screws in) in place. Remove the clip, then slowly pull the cartridge from the retaining sleeve. This cartridge is available at most HD & Lowes stores. A little pricey, but if you have time, Call Moen and they will send you one free. Good luck!
2004 F-450 CC, DRW 6.0 Classy Chassis
1997 33' Alpenlite St. Andrews
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Alpenlite Travel Club #5955
Vietnam Vet '67-'68
Extreme Makeover RV Style! Click here!
