RV.Net Open Roads Forum: Tow Vehicles: nitro and pop up?
Search only in Tow Vehicles
 > nitro and pop up?
EllieThomas
Redding, California
Posted: 07/31/08 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
hi,
My daughter has a 2007 Dodge Nitro and wants to look into a pop up as a step up from tent camping.
I told her that she should make sure how many pounds she can tow and that I knew just the place to find out.
I know next to nothing about pop ups as they are today. Can you tell me how much she can tow safely with this vehicle?
She would have her husband and two kids, 10 and 11 in the car.
Thanks,
Ellie
Redding, California
2006 Jayco Jayflight 20BH
2006 Chevy Silverado Duramax with Allison
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 07/31/08 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
3500 lbs is what she can tow...to keep it safe try to stay under 2500 lbs, some of the very light weight Alinerpop-ups would work great, especially if she plans on camping minimal persons. A small tent type folding camper might work, too! Like this 2500 lbs.
Some of these Fleetwoods are around 2500 lbs too! Good luck!
fickman
Fort Worth, Texas
Posted: 08/01/08 02:01am Link  |  Quote  |  Print  |  Notify Moderator
Take your GVWR and subtract your actual weight (go to a truck stop and get it). This is how much stuff you can load in the Nitro. Take the GCWR and subtract the actual weight (after calculating all that stuff you added to the Nitro). . . this is the max you can tow, assuming the tongue weight isn't too much (which it shouldn't be with a PUP).
All of this is assuming that they have the factory installed tow package.
I'd be more comfortable pushing closer to my full tow rating with a popup camper. . . they don't have the wind drag that TTs do. I've always had great experience with Fleetwood PUPs, and I've also been impressed with Starcraft.
2005 Chevrolet Silverado 2500HD Crew Cab SB LS 6.0L 4x4 4.10
DW, DD (May, 2007), DS (October, 2008), and me
McDonoughDawg
Peachtree City, GA, USA
Posted: 08/01/08 07:12am Link  |  Quote  |  Print  |  Notify Moderator
From the specs I just saw, the Nitro with the Auto and Tow package is rated up to 5,000 within certain limitations.
dodge guy
Chicago, western subs.
Posted: 08/01/08 07:42am Link  |  Quote  |  Print  |  Notify Moderator
Need more info. on the Nitro. 4.0, 3.7, gear ratio, tow pkg?
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
EllieThomas
Redding, California
Posted: 08/01/08 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all. I just got back from a business trip and am checking in. This will get her started. She does NOT have the tow package but assumes she could get it put together from the dealer.
I will send her the information and links.
You are the greatest,
Ellie
Yodelpup
Cornelius, OR
Posted: 08/01/08 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
http://www.livinlite.com/pdf/2007%20tow%20ratings.pdf
According to this, if she has the automatic, or the manual with tow pkg., the tow rating is 5K.
08 Fleetwood Saratoga
07 Toyota Tundra 5.7
 > nitro and pop up?
