2RVers
For the first time I passed a Sterling pick-up truck in Sarasota, Florida. Looked a little like a Chevy with black fender flares.
Rob and Jet
2000 Ford F550 with custom bed
1998 Jayco Designer 3710 fifthwheel
Fred and Barney de Katz
snownyet
Western NY
Its a Dodge!
2007 Montana Mountaineer 307RKD
2006 Chevrolet 2500 4x4 crew Duramax/allison
surveyorjp
Missouri
You better look again. The only difference between Sterling and Dodge pickups appearance wise is the grill and badges.
2005 Surveyor SV-291 Tows smooth as silk!
1995 Dodge Ram 1500 Laramie SLT 4x4 5.9L V8 low miles, It ain't pretty, but it's paid for!
Hornet28BHDS
Parker, PA
surveyorjp wrote: You better look again. The only difference between Sterling and Dodge pickups appearance wise is the grill and badges.
Ansolutely right! I saw one on the interstate the last time I was on.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
SoCalDesertRider
SanDiego, CA, USA
I like those Sterlings. They come standard with some things that are optional on the Rams. I think I like the grille better too. Either way, I'm sure both are good trucks.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
lc51willy
Fulltime USA
The last time I look Sterlings were class 6 trucks same size as my International class 6 MDT.
Larry
USA TRAVELER
LC&KC
MOJO (Deceased 4/10/06)
2000 International 4700 CREWCAB 530 power/Full Air ride cab.
JAKE BRAKE/ Gvwr 23,500
40ft. Prowler AX6 4 Slides/Trail Air Pin Box/HughesNet dish (
surveyorjp
Missouri
lc51willy wrote: The last time I look Sterlings were class 6 trucks same size as my International class 6 MDT.
Larry
Again, not these. These are based off of the Ram 4500/5500.
http://www.pickuptrucks.com/html/news/sterling.html
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Not only did Daimler steal the Heavy Truck Divisions form Chrysler they stole the Ram 4500/5500 HD pick up also. They call it the Bullet.
Link to Sterling truck
Don
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
pics
lesmore49
canada
Dodge is doing a pretty good job of turning out trucks, with revisions as Sterlings and I hear soon, they may do the same thing for Nissan.
lesmore49
