RV.Net Open Roads Forum: Class A Motorhomes: Rust on bottom side of coach
 > Rust on bottom side of coach
teeznu
Posted: 08/01/08 05:42am Link  |  Quote  |  Print  |  Notify Moderator
Our coach is only 3 yrs old. Recently, while lubing the jacks, I noticed the bottom side is rusting terrible. Any suggestions, like some type of solution you can pour into a pump up sprayer, and spray the Hel--ooo out of it vs. a piece of sandpaper and spending a month of Sundays working underneath.
Appreciate your direction.
Stephen
Turbo Diesel Dude
Green Mountain, NC
Posted: 08/01/08 05:48am Link  |  Quote  |  Print  |  Notify Moderator
Better to spend "a month of Sundays" and take care of it. Then you can spray undercoating on it from a "rattle can" That was the first thing I did to the back of my 2005 Dodges bumpers when I bought it as I'd seen some rusted pretty badly from salt on the roads in winter up here. JMHO
charles weidman
CSpenceFLY
Macon,Ga
Posted: 08/01/08 06:12am Link  |  Quote  |  Print  |  Notify Moderator
There is a product called POR-15. It chemically changes the rust into a solid surface.
"You're lucky to be alive my friend."
Quote from the "Do it yourself police" and many others that have known me.
magicbus
LBI, NJ
I used a spray product from Rustoleum made for spraying directly on rust that isn't flaking off in chunks. I sprayed it anywhere I could reach - underneath, in compartments, etc. Only took 3-4 cans and worked like a champ. Should be available at any hardware store. IMHO it beat the heck out of the professional solutions that are a) costly; b) time-consuming; and c) messy to do and clean up. Yes I'm sure it does not last as long but touchup once a year as needed takes only a half-hour out of my life.
Dave
Life doesn't come with a safety fence around it... enjoy it anyway.
Ivylog
Blairsville, Ga. USA
Posted: 08/01/08 06:20am Link  |  Quote  |  Print  |  Notify Moderator
I'd spray it with phosphoric acid, Home D sells it the paint dept and then undercoat it.
04 Monaco Dynasty 42' quad slide
Big Katuna
Deland, FL
Posted: 08/01/08 06:54am Link  |  Quote  |  Print  |  Notify Moderator
I second the POR recommendation. POR stands for Paint Over Rust. Good stuff.
My Kharma ran over my Dogma.
helperzack
Port St. Lucie, FL
I am getting ready to order some of this stuff. Heard it is great.
Boeshield
’07 Coachmen Mirada 310DS
Counting my blessings with my high school sweetheart.
3 kids, 39 foster kids(not all at once) 2 boys currently
Do you have room for a child? Consider fostering/adopting a child. Thousands of children are in need of a loving family.
rooster
somewhere in the Ocooch
Posted: 08/01/08 07:53am Link  |  Quote  |  Print  |  Notify Moderator
I recently used POR (2 mos. ago) on a badly rusted propane tank. I can see pin pricks of rust again in some areas. Used it other places too & they look fine. so maybe I didn't get enuf on. Mostly pretty happy with it so far.
Tony & Cam
1999 Tradewinds 7371
2001 Cherokee
Polishnurse
Schodack, NY
Posted: 08/01/08 08:00am Link  |  Quote  |  Print  |  Notify Moderator
I do the same as magicbus, first time used 3 cans of spray paint, one can every year after. Have on of those creepy crawlers to make easy work of it.
millikeg
New England
Posted: 08/01/08 08:44am Link  |  Quote  |  Print  |  Notify Moderator
Another vote for POR-15....expensive but works as advertised!
2004 Coachmen Sportscoach Elite 402 TS
