RV.Net Open Roads Forum: Tow Vehicles: Dodge 2500 5th Wheel Hitch Placement?
Search only in Tow Vehicles
 > Dodge 2500 5th Wheel Hitch Placement?
ValkSmile
Cincinnati Ohio
Posted: 08/01/08 08:16am Link  |  Quote  |  Print  |  Notify Moderator
I'm gettin ready to get my 5th wheel slider hitch installed and I wanted to check with you guys to ask where exactly the hitch should be placed in reference to the rear axel? On the rear axel or 1 inch forward or what? Reese 16k Slider
Thanks
2006 Dodge 2500 CTD 4x4 Quad Cab
2009 WildWood XL 286FBSRV
1999 Custom Valkyrie
SoCalDesertRider
SanDiego, CA, USA
Posted: 08/01/08 08:38am Link  |  Quote  |  Print  |  Notify Moderator
Just forward of the rear axle when in the towing position.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
mpfireman
Cook County Il
Posted: 08/01/08 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Sometimes braces or other items are in your way when installing the hitch. Just try to have the fivers hitch pin close to the center of your rear axle in the tow haul mode. Being off an inch or two from center either way will make no difference.
1998.5 Dodge Ram Quad Cab Cummins
1998 Sunnybrook 27RKFS Fiver
mkirsch
Rochester, NY
Posted: 08/01/08 09:27am Link  |  Quote  |  Print  |  Notify Moderator
An inch or two ahead will transfer some weight to the front wheels. Not much, but some.
I saw this show Extreme 4x4 where they built this Humvee with a gooseneck hitch... The ball must've been 6" behind the axle, and the trailer was a beefy looking rig. Boy was that rig running uphill...
SoCalDesertRider
SanDiego, CA, USA
Posted: 08/01/08 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
The ball (for a gooseneck) or pin (for fifth wheel) should never be behind the axle centerline when towing down the road. The exception is a class 8 semi truck hauling an RV fifth wheel, which is way way way below the truck's typical trailer towing ability.
Ductape
On the Road
Posted: 08/01/08 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
Well, it's not like you have choices.
IF the hitch is properly installed they will follow the manufacturer's specific measurements for your vehicle. Moving it around to suit individual preferences is hardly ever possible due to all the body and frame obstructions.
Surveyor SV-234 >Equalizer> H3
Previously a fiver crew.
Hannibal
Gas Station
Posted: 08/01/08 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
The Dodge's bed cross ribs and frame don't allow for any choices in where the Reese is mounted. I've installed my hitch in my last five Dodges. Reese provides measurements that put it right where it needs to be. Not to worry.
'05 2500HD Dodge 5.7L Hemi 5spd auto/3.73 SLT. 95k miles
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins
'07 KZ Jag 28JFSS.
Bill1374
Saratoga Springs, NY
Posted: 08/02/08 08:00am Link  |  Quote  |  Print  |  Notify Moderator
What Hannibal said. reese has excellent instructions to tell you where to mount the hitch.
Bill
2000 Hitchhiker II Rio Grande
2000 Dodge 3500 dually Cummins 5 speed Edge EZ and guages
Madhatter1
Madeira Beach FL
Posted: 08/02/08 08:07am Link  |  Quote  |  Print  |  Notify Moderator
I have a 3500 srw and a 3500 dually. Both have the hitch exactly where Dodge spec says it needs to be. Both pull the 14K trailer with no handling problems or weird sensations. I don't know how a different mounting position can fix whats not broke. 2 cents.
JIMNLIN
Big Cabin, OK
Posted: 08/02/08 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
my 16k manual slide Reese is mounted zero over the rear axle on my '03 2500 3rd gen Dodge. 2200 lbs of pin weight adds zero the the trucks front axle.
Jim
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
