Ken Washington
Pleasant Garden, North Carolina
I have a couple of small cracks in the fiberglass of my roof. Does anybody have any suggestions as how to fix these. They are not leaking to the inside yet and for piece of mine I want to do something with them. Any suggestions would be appreciated.
Ken
2004 Patriot Beaver Gettysburg
Cummins ISL 400HP Turbo Diesel
Allison 3000-MH 6 Speed World Transmission
Roadmaster M-Series Chassis
TOAD-2005 Honda Element
wolfe10
First, verify that they are indeed cracks in the fiberglass, not just the gel coat (obviously, first determine if this IS gel coated FG).
If these are deep cracks, the proven method of repair is to dremel a wide "V" to the bottom of the crack. Use West System Epoxy and glass mat/roving to build up the "V".
If the crack is not structural, a shallow "V" and West System Epoxy will seal it. Color can be added to the West System to match the roof.
http://www.westsystem.com/
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
psyflyjohn
San Diego, CA
Just a thought... What if you used a tiny drill to "terminate" the end of the cracks, then used Eternabond over the cracks?
Ken Washington
wolfe10,
It is gel coat and not deep. I was thinking that maybe a little clear epoxy might seal it. What do you think?
Ken
wolfe10
Ken Washington wrote: wolfe10,
Ken
Should work as long as you scuff up the area-- maybe tape off an area 3/4" on either side of the crack and rough sand the surface and perhaps dremel the crack. Again, color can be mixed into the Epoxy to match the roof.
And if this area will not be visable, and the crack is not structural, Eternabond would certainly seal the area.
Magician
Belleville, ON
I notice from your signature that your MH is a 2004 model. Some manufacturers give an extended warranty on the roof. It's possible that your may be taken care of by a warranty.
MCP, IEEE, CCP, BJCP
Traveling, Working, and Judging
RAGster
Marietta, Georgia
MarineTex is a great epoxy gelcoat repair product available at West Marine.
Glenn
RAGster
1986 Wanderlodge PT-40
Marietta, GA
deandec
El Dorado Hills, CA
Can MarineTex be painted or colored?
Dean
95 CC Magna Jeep GC
(Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes.)
RAGster
Marietta, Georgia
deandec wrote: Can MarineTex be painted or colored?
yes...sanded too.
