RV.Net Open Roads Forum: Class A Motorhomes: tuning Wineguard power antenna
 > tuning Wineguard power antenna
horacebcupp
Johnson City, TN
Posted: 08/02/08 06:37am Link  |  Quote  |  Print  |  Notify Moderator
Now that have my DPTv converter boxes installed and working, sorta, how do I tune the batwing antenna. Before I simply tuned the station and rotated the antenna for best picture. Now, I put TV on channel 3, turn on the box and select channel with the remote for the box. Instead of a fuzzy picture, I get a dialog box telling me the signal is weak. I know, that channel may not be digital, yet, but do I need to rotate the antenna and how do I know the endpoint?
Foretravel, 2003, U320, 38ft.
Honda, 2003, CRV
Cliford
Whidbey Island , Washington
Posted: 08/02/08 07:17am Link  |  Quote  |  Print  |  Notify Moderator
If you don’t have a pass though converter and the station is not digital than you will get no signal.
Aim up by Seattle and no one transmits digital yet.
If I know that I know now I would have bought a pass though converter.
2003 2500 Dodge CD
2000 Damon 27R Hornet
2005 Chev 1/2 ton Silverado,1999 Palomino B-800 Bronco Camper
horacebcupp
Johnson City, TN
Posted: 08/02/08 07:23am Link  |  Quote  |  Print  |  Notify Moderator
Cliford. Sorry about that, DPTv IS a pass thru box. Found out, however, that by turning OFF the box, the tuner on the TV works as before, ie, like no box was there.
Lt46
Cape Cod, Ma.
Posted: 08/02/08 07:29am Link  |  Quote  |  Print  |  Notify Moderator
On my Zenith DTV boxes, I have a button on the remote indicating "signal". I hit that button and a slide bar appears on the TV screen. By rotating the tv antenna incremently, I can make the slide bar signal indicator move from "bad" to "good" signal. In short, yes, moving the antenna slightly will improve or cause to deteriorate, your digital signal.
Peter & Dawn
97 Winnebago Adventurer 37RW
91 R2500,454 Chevy Suburban
96 Prowler 27X SOLD
Yamaha EF2800I
IAFF L-792
-Gramps-
Portsmouth VA
Posted: 08/02/08 08:00am Link  |  Quote  |  Print  |  Notify Moderator
Digital signals are distance related and omni directional just like analog, so you twist the attenna just the same. My box has a signal strength meter so it makes it a bit easier to "tune it in".
___________________________________________
08 Holiday Rambler Vacationer 38PLT Workhorse UFO GAS Pusher Chassis
06 Saturn Vue toad, SMI Breaking sys,Blue Ox tow bar. Myspace site and blog
Gramps and family
Drive a UFO.com
jhilley
Buxton, ND
Posted: 08/02/08 09:57am Link  |  Quote  |  Print  |  Notify Moderator
I went to the Winegard seminar at the Winnebago GNR a couple of weeks ago. The batwing antenna receives analog signals off both sides of the antenna, but receives digital off only one side. Unless you know the direction of the digital stations you have to do scans with the digital converter with the antenna in 90 degree changes then tune to a digital station and use the digital converter signal meter to fine tune the channel.
want-a-be
Indiana
Posted: 08/02/08 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Do all boxes have a slide bar signal indicator?
Lt46
Cape Cod, Ma.
Posted: 08/02/08 10:56am Link  |  Quote  |  Print  |  Notify Moderator
want-a-be,
Good question and one I can not answer. My Zenith DT901 box's do, and have analog pass-through as well.
Wherever I happen to park
Posted: 08/02/08 11:03am Link  |  Quote  |  Print  |  Notify Moderator
Well, there are basically 3 ways two are the same but reversed
First turn clockwise (Anti-clockwise) till you loose signal, Remember spot
Then turn anti-clockwise (Clockwise) till you loose signal, remember spot
Park 1/2 way between the L.O.S. points
Method 2 Turn for MINIMUM signal strength, turn 90 degrees, park
NOTE many digital converters do have a signal strength meter feature
kd8wdave
Middletown,OH
Posted: 08/02/08 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
I would like to have a 'copy' of that seminar. I have NEVER heard of an antenna that will receive analog on two sides and 'digital' on only one side. I think you are getting hyped. BTW I'm into radio-rf signals all the time. My batwing doesn't know the different between analog and digital. JMHO.
cheers
