RV.Net Open Roads Forum: Class C Motorhomes: Generators that sit idle
 > Generators that sit idle
visch1
CAPE COD, MA
Posted: 08/03/08 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
"What is Sea Foam and where does one get it? Is it similar to Stabelizer?" It does more than regular stabalizer : http://www.seafoamsales.com/motorTuneUpTechGas.htm
I get it at NAPA. GOOD STUFF.
All these replys has me scared the thing will fall apart as salt is used on the roads in the winter and I live in a salt laden atmosphere less than 1/2 mile from the Atlantic Ocean. Arizona here I come!
* This post was edited 08/03/08 05:11pm by visch1 *
Cool Mike
Mendocino. Calif.
Posted: 08/03/08 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
SeaFoam is used big time in the marine industry, and with outboards, and I have herd good things about it, but I dont use it on my MH.
Even if you live in an area where salt is used on the roads, or close to the ocean, like I do, just exercise your generator under a 50% or more load for 20 min a month or more is all you need. In the winter I use one or two 1500 Watt portable heaters, so it warms up the inside of the MH as well, for free.
This will pay off in reliability.
I have the vary common Onan 4KW Micro Quiet generator, with 550 hrs on it, and when I start it cold, if I just hold the start button down, it will crank for 15 to 20 sec before it starts. But if I push the start button for just 5 sec, release it for 3 sec then push it again it will start immediately with the second push, every time. I think the button release must be setting the choke, because it sure starts quicker this way.
And maybe my choke is just sticky, but it works for me.
2001 27' Four Winds Class-C E-450 V-10.
Buick Park Ave Ultra, Ford Ranger PU, JD 500 backhoe.
1941 Farm All "A"
visch1
CAPE COD, MA
Posted: 08/04/08 01:49am Link  |  Quote  |  Print  |  Notify Moderator
Hi Mike. I use Sea Foam in all my engines from the E-Tech to the weed wacker and ocassionally the car. I expect to leave around 1/2 or so tank of fuel in the MH and stabalize that also. I've only used the gen around 5 times and was frustrated by what I call fair starting quality like yours. I'll try your procedure later.
MrTravelDecal
wandering
Posted: 08/05/08 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
my onan 4k microlite (same as microquiet except does not have onboard diagnostics) starts the same way as others. I just push the button for 5 secs, then pause and push again to start. When it is warmed up already this procedure is not necessary.
Like old travel decals? me too!
Two cannibals were eating a circus clown,
One cannibal says to the other-
"Does this taste funny?"
