meadje
canada
i am new to 5th wheel rving but i have a question,can i pull the trailer with the propane running on the fridge to keep it cold
91GMC K1500,Reese 16k double pivot,Prodigy,Dutchmen 26f
trnfla
Tampa
yes
Have a great time camping,
Terry
Please say a Prayer for my 12 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
JFG
TN
That's what it's for... use it.
Fred
Polishnurse
Schodack, NY
Most folks do use there propane when going down the road. If you so chose to, it is also recommended that you turn it off when refueling at a gas station. The newer RV's are equipped with a flow switch. Should you break a line and you propane go to full flow, it is suppose to shut off. Bill
ArcticDodge
Sammamish, WA
I run with it on all the time.
2009 Komfort 256TS Yamaha EF2400iS
2001 Dodge Ram 3500 QC 4x4 Cummins DRW
2001 Sebring Convertible
2005 DRZ400 - 2005 CRF150 - 2001 XR80
1 Wife 2 Boys
1 Trixie (Bichon Frise)
Only 27 years to retirement!!!!
ilvtravln
Calif.
Yes, been doing it for 20+ years.
Art
james ryan
geismar la.
do it
2003 gmc 3500 dually 2004 prowler regal
meadje
canada
thanks for the info i will start using it now
K-Star
Home is where I park
I do it all the time. I only turn it off when necessary to go thru a tunnel or over a bridge, etc. Also I turn it off when refueling if the diesel pumps are too close to the gasoline pumps. Gas fumes and open flames tend to ruin ones day.
JJnLilly
Ohio
Have found that the refrigerator will maintain a low temp and even the freezer will keep when on the road for up to 8 hours. I now turn the unit off, basically to save on propane. No need to burn off gas and dollars if not warranted.
2007 Ram 2500 QC CTD
2004 Cougar 290RK
