mikehart92
Oklahoma
yes
2005 Chevy 2500HD.............6.6 D/A, 4x4, Crew Cab
Lovedays
Greensboro, NC
Never used to, but after spending time on this forum I decided to try for the trip I'm on now, and I gotta tell you, its nice to have a cold fridge.
Eric, Melissa, Morgan, Andrew
and Sam the Camping Canine
2006 Starcraft Antigua 235SRG
2004 Toyota Tundra SR5 Double Cab V8
www.thelovedays.com
cdrcos
St. Paul, MN
JJnLilly wrote: Have found that the refrigerator will maintain a low temp and even the freezer will keep when on the road for up to 8 hours. I now turn the unit off, basically to save on propane. No need to burn off gas and dollars if not warranted.
Then it would also stay cool overnight, do you turn it off overnight when you are stopped somewhere?
Joe & Barb
2002 F-350,PSD,Crew Cab
2003 HH II LS 32.5 UKTG
*finally retired! *
lv2rom
Kansas City, Missouri
cdrcos wrote: JJnLilly wrote: Have found that the refrigerator will maintain a low temp and even the freezer will keep when on the road for up to 8 hours. I now turn the unit off, basically to save on propane. No need to burn off gas and dollars if not warranted.
If it stays cool well anyway, then it would not cycle very much even if you had it turned on. I think this is a negligible savings for a real PITA process. My food, and a possible replacement board, cost a whole lot more than a few cents of propance. I run it all the time....Brian
2005 F350 Dually -AFE air box/MRSP exhaust/Bags/Bilsteins/Energy Susp./Michleins
2002 Hitchhiker Fiver 29.5 RLBG - Moryde Pin/Gas shocks/Michelin XPS Ribs
1996 Layton Fiver 21ft. Totally reconditioned..Love it!!
texasjayco
Texas Hill Country - west of Austin
I always run mine while traveling too.
But that raises a good question...any idea how much propane it does burn to run the fridge?
Mark
2008 Jayco Eagle 291RLTS
2008 Ford F-350 Lariat
PICS
My home town
juzplanekrazy
Huntington Beach Ca.
Yes you can do it. I do all the time.
Just make sure if you have a slide out on the refer side that when it's closed the hose is not kinked like mine did one time and spoiled all the food inside after a 6 hour drive.
Boy did the wife get on me about that one
autojohn 2
95687
yes it is ok
paulonius
Athens, GA
I run with mine on too. Never a problem. With that said, someone reminded me not long ago that if my rig catches fire when refueling due to the propane being on, then my insurance company will be saying, "We never knew you." Sort of like their digging out the computer from my truck after an accident to see if I was speeding or how soon I applied the brakes.
I still will run with mine on.
2001 Chevy 2500HD and a Rockwood 30' Fiver
ONE INCONTINENT POODLE AND ONE YAPPER POODLE: (And why were we not warned about poodles) Is there a recall on Toy Poodles????
Fully retired and no desire to go back.
cwit
new york
Your insurance company will cover because they are designed to auto switch to propane when you onplug electric.
balvert
Windsor, Ontario
I run with mine off. I know that is tantamount to heresy for some but too easy to forget to shut down while refueling. To me an open flame in a gas station is just too risky, albeit the risk is small. Just my way of doing things and the reefer stays cold for 10 hours if you leave the door shut.
Casey & Karen, Border Collies, Polly & Babe
04 Newmar Mountain Aire 34RDCK with tandem duals & XPS Ribs, Pullrite 25.5K Super 5th, MorRyde, Solar, RotoChoks
03 Dodge DRW Sport, Cummins, 4.10, 6 spd, MBRP SS Exhaust, Jacobs E-Brake, Tire Sentry, BrakeSmart
