RV.Net Open Roads Forum: Computer won't power on ? ! ? ! ?
 > Computer won't power on ? ! ? ! ?
4HPYCMPRS
Niagara Falls, Canada
Posted: 08/02/08 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all of the info,
yes, MSN is my homepage. How's that important? I tried the power cord thing and nothing!
I think I'll pop the cover off tomorrow and check it out. I do not hear the cooling fan either!
I'll try the battery thing tomorrow also. I'm always learning.......
Mark.
'08 Chevy Avalanche LT3 6.0L (366hp) 4.10's
'06 Rockwood Roo 23SS. Equal-i-zer/P-3
'06 Honda EU3000iS Garmin Nuvi GPS.
Me ('71), DW ('70), DD ('01), DD ('04).
A wiseman once said "GIT-R-DONE"
'08 nights camped- 28
CAMPING PICS & MODS
Gale Hawkins
Murray, KY
Posted: 08/02/08 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
Watch the fan from the rear to see if it flicks at all.
confusedsoul
Huron, SD
Posted: 08/02/08 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
I was asking if you had MSN messenger as I was going to walk you through some things.
fj12ryder
Platte City, MO
Posted: 08/02/08 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
Take it to a shop and have them take a look, they have the necessary equipment to check out what may be wrong. As to the comment about the PSU being easy to change, not if it's an older Dell: their PSU's are proprietary and not easy to come by.
Howard and Peggy
"Don't Panic"
NGRRFan
Colo. Spgs., CO
Posted: 08/02/08 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
I just worked on an eMachine at church, and what I found out was that the power supply went out, which is typical for those computers, and when it goes it also takes out the motherboard.
Bottom line, in my trouble shooting I took the computer to a local shop and they had a power supply tester they could hook up and check the power supply. Once we found out it was bad we then took a new PS off the shelf and connected it to the motherboard and confirmed that the motherboard was bad as well.
Now the upside to all this was that I was able to use the old CPU and memory, as well as other cards, on a new motherboard along with a new power supply. We got a "new" computer for under $100.
Well that was until we found out we couldn't use the restore CDs as they were too badly scratched by the previous owner and so we had to purchase a new XP Home cd, another $95.
Rich,and Tobi (the rescued dog)
Prowler 5ver, 84 Ford F250
KCOCOLOR78 Weather
Colo. Spgs. CO
weasel4
Alberta
Posted: 08/02/08 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
4HPYCMPRS
Have you tried booting into Safe Mode to turn off the Power Saving Mode?
BTC
Everything in moderation, including Sobriety.
chewbear
Lindenwold, NJ
Posted: 08/02/08 10:38pm Link  |  Quote  |  Print  |  Notify Moderator
Does it beep and the key board lights flicker? No fan? power supplie likly.
If you do get these the hard drive isn't spinning up big ouch.
New to Us
2002 Fleetwood Discovery
330 cat.
djncas
Waynesboro Pa.
Posted: 08/02/08 11:13pm Link  |  Quote  |  Print  |  Notify Moderator
Safe mode won't do it since you can get on line go to Tiger Direct.com and order a power supply. I can tell you how to jump start it but you need a second working PC to do it, just like jumping a car. anyway get at least a 400watt power supply takes about 3 days to get it or go to a Circut City or Staples to get one, You will pay more for it but it will be a same day repair
The journey of a thousand miles begins with a broken fan belt and leaky tire.
Carl and "D"
Drago the Rotten Rotty (Service Dog)
2007 4x4 Quad Cab Hemi Ram/ 2008 Keystone Hornet 26 RBS
