RV.Net Open Roads Forum: Tow Vehicles: Engine RPM vs MPH
Search only in Tow Vehicles
 > Engine RPM vs MPH
J Gerber
Odem, TX
Posted: 08/04/08 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all you guys for your replies. Sorry to be so late in replying, been on the road for the last 3 days. I have an 08 2500HD with a 6.0L and 6 speed trany. Guess I had better run in 4th at 2700rpm for the best performance. Thanks;
J Gerber
pronstar
The LBC
Posted: 08/04/08 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
All else being equal...a gasoline engine is more fuel efficient at low RPM (lower friction and fewer power strokes) and larger throttle openings (reduced pumping losses against a closed throttle).
I'm not an engineer either but I am a member of the SAE.
2007 Dodge Ram 2500 CTD 4x4/QC/LB
2008 Stellar 23' Toy Hauler
JIMNLIN
Big Cabin, OK
Posted: 08/04/08 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
best performance ?? If it towing performance it will change with terrain/load/outside ambient temps/altitude/lower or higher octane gas/etc. As you tow with the same rig you will gain experience in determining which rpm works best for the truck for that particular load. Long flat stretches with a 30-35 mph tailwind your going to find 2700 rpm is a waste of fuel. We see that quite often in western TX/OK/KS/NB. Turn around and face that 30-35 mph head wind and 2700 rpm won't do it with a tall heavy load.
Jim
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
 > Engine RPM vs MPH
