RV.Net Open Roads Forum: Fifth-Wheels: JT Stongarms question
 > JT Stongarms question
Prin
Central Ohio, USA
Posted: 08/02/08 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
I have the JT Strongarms and was wondering if after loosening the t bar and then retracting the landing gear, if it is necessary to retighten the t's to keep them from vibrating loose and falling off?? It is a pain to untighten, raise and then retighten each time. Will they stay in and/or do they have a stop of somesort? Thoughts? Ideas?
Thanks,
Ted and Carol
2008 Cameo RE373S
Chevy Silverado 2500 HD Diesel
Yamaha 2400i generators
Goldwing Motorcycle
Four Winns Boat
Z3 BMW
Retired Educators
rusticwood
Seymour Mo
Posted: 08/02/08 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
I used to tighten mine each time but don't anymore and haven't lost one yet. I haven't traveld over 200 miles in a day either so keep that in mind.
larry barnhart
wenatchee. wa usa
Posted: 08/02/08 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
I don't tighten much so a small turn is all it takes to be ready to travel. this means I don't tighten the T nut to travel.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
cruz
Prescott, AZ
Posted: 08/02/08 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
I always just snug them up before travel. just makes me feel better.
CRUZ
HR & Beth
2006 Chevy Silverado LT3 3500HD, DRW, D/A, CC, LB, 4x4 and RED
2008 Jayco Designer 35RLTS
Cassie - pure Black Giant Schnauzer
Mollie - pure White Mini Schnauzer (the boss)
tvman44
Southwest Louisiana
Posted: 08/03/08 08:49am Link  |  Quote  |  Print  |  Notify Moderator
There is no stop, I just snug them so they don't vibrate and fall out. Just a precaution, would hate to arrive and find missing T Bolts although I carry a couple of 3/8" bolts in my tool box to use as temporary replacements in case I would lose one.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Strange-Jaybirds
Michigan
Posted: 08/03/08 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
With mine, I remove my T handles and place them in a side compartment, and then when I go to set up, I put them back in. Has work well so far.
Happy Camping....
pupeperson
Silver Springs, NV
Posted: 08/03/08 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
If I remember correctly, mine came with instructions to lightly tighten the T-handles when traveling to prevent their falling out.
Titanium Owner
Sacramento, CA
Posted: 08/04/08 09:06am Link  |  Quote  |  Print  |  Notify Moderator
Check out the stabilizers by Winfield RV Products. There are no T-handles to come loose and they can be installed with no drilling.
The website is www.winfieldrvproducts.com.
boatdoc
South Coast Oregon
Posted: 08/05/08 02:36am Link  |  Quote  |  Print  |  Notify Moderator
I drilled the end of the T handle's and safty wired them onto the tube, they won't go missing now.
2006 SD350 CC 4x4 TS
2009 Heartland Bighorn 3670RL
taxgod4u
Bay Area, CA
Posted: 08/08/08 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
we have a winner!
All things in moderation, except acceleration!
Zip ties, the duct tape of the new milenia!
2001 F250 Powersmoke turbo diesel, 3.73LS
Crew Cab, SRW, SB, 6 inch lift, Single 28 inch semi airhorn underneath! SCMT, A Pillar mounted, Pyro, boost and Trans gauges.
2005 Wildcat 29RLBS, Prodigy, 2 EU2000i's Draw Tite 18K Signature Series, front receiver, on board air, Airlift HD airbags
2003 Ford Explorer XLT 4X4, V8, 5sp AT, 3.73LS
2003 Ford Explorer Eddie Bower 4X4, V8 5sp AT, 3.73LS, Dual semi air horns underneath
2002 XR50, PW50
