moloss
heart of dixie
I want some opinions on what to do with the rear end of my truck.....when it's loaded with either the gooseneck or the truck camper my rear sits lower than the front.....the truck has the factory overload spring but I'm looking for a way to keep it from squating to much......what would y'all do? thanks....
edited 08/03/08 07:00am by moloss *
1986 CJ 7 "locked and ready"
2004 GMC 3500 srw 8.1/Allsion 4x4 crew cab long bed
2007 yamaha grizzly 700
2006 kawasaki 50
donn0128
Pronounced Ore-gun
Weigh the loaded and unloaded rig to determine EXACTLY how much load you are talking about and then come back with some numbers for opinions.
Donn
spikes227
long island new york
Head off to a good truck spring shop loaded. They should be able to hook you up after a few measurements.
#1 dano
OR
Firestone Ride-Rite airbags.
SoCalDesertRider
SanDiego, CA, USA
There are a myriad of suspension upgrade options available...
Tork Lift has the Stable Loads, which are bushings that install on the overload spring frame bumpers that effectively lower the height of the bumpers so the overload spring contacts the bumpers sooner and helps keep the truck from sagging so much.
Another option is to take the truck to a spring shop and have them re-arc the overload spring so it is taller and contacts the bumpers sooner.
Another option is to have the spring shop add leafs under the single overload leaf to make it a multi-leaf pack that can take more weight.
Another option is to add a helper leaf or two to the main leaf pack.
Another option is to replace the stock leaf packs with heavy duty leaf packs or have a local spring shop build heavy duty leaf packs for the truck, or you can order a set of heavy duty leaf packs from a spring supplier and put them on yourself or have a mechanic put them on for you. I got my heavy duty leaf packs from Stengel Bros.
There are also aftermarket add-on helper spring solutions such as Firestone Ride Rite or Air-Lift air bags, Super Springs helper leafs, Timbren rubber helper springs, Roadmaster helper springs, Helwig helper springs, and probly a number of others I don't remember.
The only ones to stay away from are air shocks or coil-over shocks. Your shock mounts were never intended to support the weight of the vehicle. Also be careful with air bags and timbrens that you do not depend on them to hold up the weight of the truck and take the weight off the springs, as your frame was not made to support all the weight at one point. They are fine for helping out the springs though if used judiciously.
Prepare to be thoroughly confused by all the possibilities as each person who responds relates their own unique way of solving the problem that has worked for them.
edited 08/02/08 10:40pm by SoCalDesertRider *
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
waflhtrider
Pierce County Washington
The cheapest solution would be "Timbrens". My solution was air bags with on board air compressor.
WAFLHTRider Ryan(W7SFO)& Beth Pierce County WA.
Nights Camping in 2008 52
NWSpring Rally 2008 Pictures.
My Web Page
My Myspace
Pictures
Old photos
2005 Dodge RAM 3500 Long Box 2WD Quad Cab HO 5.9L CTD
2006 Carriage Cameo 35KS3
2004 HD FLHTI
My Blog
#1 dano
OR
I keep my Firestone Ride-Rite air bags at approx. 25 psi, when not carrying or pulling a load. I don't have an on-board compressor, as it was too expensive at the time of my air bag install, and from what I have heard many times, they are problem prone. Small compressors are notorious for being cheaply made.
moloss
heart of dixie
thanks for the replies.....the gooseneck loaded with the tractor will be in the 13-14k range.....my understanding on the truck camper is that it's 2300#'s dry.....the truck does great towing the gooseneck or carrying the truck camper, I just want to cut down on everybody flashing their lights when I'm driving at night....here's a couple pics to give an idea.
ib516
Up here!
I think SoCalDesertRider about covered it - at least everything I was going to say.
2004 Cougar 301 BHS 6580# Dry, 9000# wet, 9600# GVWR)
2007 Dodge/5.9L Cummins 3500 SRW Megacab 4x4/3.73
Hypertech Max Energy
"MEGACASPER" 10100# GVWR, 5200# FGAWR, 6200# RGAWR
PICTURES
ELIM 3000 Gen (still going )
Collision Reconstructionist
ScanGauge2
88beast
pa
get bigger springs if its a daily driver just get the overload beefed up (bigger/more leafs)
or if its just a tow beast then go with bigger springs
i just noticed is the nose of that gn higher than the deck height?
it looks way too high or maybe its just the pic?
ive heard that can cause more hitchweight (pulling effect) but i dont tow gn
