RV.Net Open Roads Forum: Tech Issues: gorilla glue for exterior
 > gorilla glue for exterior
Treefrog
California-Oregon border
Posted: 08/03/08 12:29am Link  |  Quote  |  Print  |  Notify Moderator
A couple of things fell off the motorhome (a wind deflector and a "dynamax" plastic logo.
I was thinking to use Gorilla Glue; anybody see a problem with that application?
2000 Country Coach Intrigue 36' 350 Cummins ISC
2002 Honda CRV
FMCA 351235
Look for us at Civil War Reenactments and the SCA.
vikx
Washington State
Posted: 08/03/08 01:02am Link  |  Quote  |  Print  |  Notify Moderator
Gorilla Glue tends to "grow". It's like spray in expander foam in a bottle. If you can clamp together, it works. On a logo, I'm thinking it might make a nasty mess. The "overglue" is fairly easy to trim but I doubt you could clamp it tight enough. (experiment first to see if you like gorilla glue) Why not use automotive trim cement or two sided tape and some small screws? Am not sure about the wind deflector. VK
Bumpyroad
Virginia
Posted: 08/03/08 04:31am Link  |  Quote  |  Print  |  Notify Moderator
yep, I'm not terribly impressed with the "stickiness" of GG, but when used with a little moisture where it can swell up like replacing a chair piece into a leg hole it works great.
bumpy
Polishnurse
Schodack, NY
Posted: 08/03/08 05:49am Link  |  Quote  |  Print  |  Notify Moderator
Think you might be better off using a five minuet expoy. I've had good to great results with Gorilla Glue with wood, and as vlkx say's it likes to grow. Just a little bit to much and you carve a hole new RV out of it. JM2Cents Bill
lv2rom
Kansas City, Missouri
Posted: 08/03/08 07:38am Link  |  Quote  |  Print  |  Notify Moderator
I'm not impressed with GG either...not only does it grow, it turns brittle after a while and loses its adhesion. For what you are talking about I would use Emblem tape (gray with red plastic backer) available at your local auto parts store. Don't use the white foam tape. Clean both surfaces well with rubbing alcohol, apply, and hit it with a heat gun (gently) or hair dryer. This is the stuff they use for window rain shields, deflectors, and other add ons.
If applied properly I've never had a failure....Brian
2005 F350 Dually -AFE air box/MRSP exhaust/Bags/Bilsteins/Energy Susp./Michleins
2002 Hitchhiker Fiver 29.5 RLBG - Moryde Pin/Gas shocks/Michelin XPS Ribs
1996 Layton Fiver 21ft. Totally reconditioned..Love it!!
Dogbone
Ontario Canada
Posted: 08/03/08 08:04am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, I would use 2 way tape if you can, they make different strengths, get the good stuff and like the above poster says clean with rubbing alcohol first, let dry and apply.
2006 Holiday Rambler Vacationer 35SBD
36ft Workhorse 8.1
bill h
el segundo
Posted: 08/03/08 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Another mixed-feelings GG user here.........I only use Gorilla Glue when I can stand by to wipe up the mess. I wish it would not set up in the bottle so fast.
Bill and Susan
84 Barth 30 tag powered by ht502/Thorley, Gear Vendors OD
Siamese Calvin and Airedale Hobbes
4WD Toyota toad
chassis
Penn's Woods
Posted: 08/03/08 11:17am Link  |  Quote  |  Print  |  Notify Moderator
Don't use Gorilla Glue, it foams and oozes onto what you don't want it to be on. I like it as a wood glue, where you can sand the excess and paint over the joint. But not on something that will be visible.
5 minute liquid epoxy (syringe type), epoxy putty (kneaded dough-type), Super Glue (cyanoacrylate) or silicone adhesive are my recommendations, depending on the materials being glued and environment they are exposed to. Read the labels of the adhesives for the materials they are compatible with. Prepare the surfaces to be glued by lightly sanding (if possible), followed by an alcohol or acetone wipe. This will give the best possible adhesion.
2003 F-250 6.0 Powerstroke diesel, 4x2, crew cab short bed
2004 Cardinal T31BH travel trailer
beachcomber_1
Alton, Illinois
Posted: 08/03/08 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
3M makes 2 excellent trim adhesives, that should work for wind deflector if you have a base to apply it to, definitly on emblem
pcmentor29
29 Palms, CA
Posted: 08/05/08 04:04am Link  |  Quote  |  Print  |  Notify Moderator
My wind deflector at the front of the hood had screw holes in it and screws where it layed flat just under the hood. You might try putting some.
1985 Toyota Dolphin 21' 22RE Auto
