Pirate
Fall Branch, TN
Just like the stories of gray water backing up into shower pan. Mine doesn't. It was dripping out of the bottom but never did back up into shower. Leaks somewhere on the top of the tank. I'm not sure which fitting and probably won't ever find out. I don't overfill my tank anymore.
97 Itasca Suncruiser F-53
2006 Vantage Mobility Dodge Grand Caravan
glsurrat
Virginia
Or you split your black water tank. Here's pictures of mine from last week:
http://nwown.powweb.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=7848&g2_serialNumber=1
http://nwown.powweb.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=7850&g2_serialNumber=1
Greg
Full-timing and soon to be retired US Navy Master Chief
Enjoying Champagne on the King Ranch!
'06 King Ranch F-350 Dually Diesel 4x4 Long Bed Crew Cab w/ Tow Boss
'07 Champagne Edition NuWa Hitchiker 3 axle 4 slide 37CKRD /w TrailAir all around
kmb1966
Houston
Hmmm. Mine does this exact same thing. If I allow the Black Tank to completely fill up, and then keep adding water, mine flows out the bottom somewhere too. I thought it was supposed to do that. Guess something is wrong with mine too.
Matthew_B
The boonies near Dallas, Oregon
just5erit
Zebulon, NC
Hey, I filled up my black tank to much one time and it started to leak out from the belly cover on the bottom. I thought it may have been a emergency over flow valve or something. I just want let it get that full again. I don't plan on taking the under belly off because there are hundred of screws holding that cover on.
2001 Chevy 1500HD 6.0L (stock)3/4 frame
DrawTite brake controller
DrawTite 15K Hitch
Firestone Airbags
2006 Flagstaff 30' 8528DS Bunk Slide/Super Slide
wny_pat
Western NYS
Christi,
How did you make out?
goin2themountains
Aztec, NM
Did he buy it? The story of checking manufacturing flaws, that is. Same here, if I go too long w/out dumping the black tank, it overflows the tank under the 5er. Good thing I don't have an enclosed belly. Chasing some Calgon water softener today to try and get the sensors working again. 6 more hours, and then a week camping. Woot.
Puller: '04 HD2500 4x4 SB,EC Duramax/Allison. Airaid intake, 4in. exhaust turbo back, ORU leveler.
Pullee: '02 Keystone Cougar 276EFS Reese 16k w/ slider.
(map is for current 5er only)
2Rovers
On The Road
TheDolls wrote: uhhhggg... okay, I guess I'll tell him...so much for "I can do it my self!" He'll probably never let me live this down! Tee he he..oh well, live and learn. Thanks for all your help folks!
Just bide your time..... his day will also come
But yes, I would tell him.
Clay L
Sioux Falls, South Dakota
In my case in my 1996 Warrior there was a split in the grommet in the top of the tank the tube from the toilet went through.
I had to pull the toilet and the closet flange and replace the grommet.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
