RV.Net Open Roads Forum: Class A Motorhomes: Ford V-10 Mobil oil filter
 > Ford V-10 Mobil oil filter
A & S
Minneapolis
Posted: 08/03/08 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
I went to Walmart to get oil and filter for our 2005 6.8l V-10 and they did not have the motorcraft brand so I bought one of the high buck Mobil M1 filters. I noticed that the filter gasket came in contact with the filter base after only two turns of the filter. After I tightened it I am guessing I only spun the filter approximately 3 turns which does not seem right to me. The part number of the filter is M1-210 but I am wondering if only three turns of the filter is O.K.
Any comments from the experts here?
Al & Sheila
2005 30B Sightseer
Toads - 70 'Cuda, 69 Superbee or 97 Lund Angler
sch911
Rochester Hills, MI
Posted: 08/03/08 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
It sounds like the rubber seal from the original oil filter stuck on the block. This is common. You may have two seals on there right now. Best to take it back off (or check the removed filter if you still have it) and make sure, it will eventually leak....
2003 Damon Challenger 348 Class A - Triton V10
Posted by Macintosh
A & S
Minneapolis
Posted: 08/03/08 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
I always make sure the old gasket is not stuck on the filter base before installing the new filter.
jimdubya
Paducah, KY
Posted: 08/03/08 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Do you still have the old filter? A quick look at it will tell you if the old gasket might still be on the filter base.
2004 Silverado 2500 Crew Cab 4x4 6.0L 3.73
2006 Dutchman Tundra 26RL-DSL
KOG
Winterville GA
Posted: 08/03/08 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
If you have two gaskets on it then it won't leak eventually. It will pour immediately.
jolooote
Miami, FL
Posted: 08/03/08 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
That does sound a bit strange. Every filter I've ever installed on anything always took 5 or more turns before it contacts the rubber gasket. After that point only tighten it another turn.
Joe&Charlotte, Nat'l SurfSide DE34D Ford 362HP 5speed
Rusty, Rosie, Snuffy Dogs
Leroy's a Conure
If a 'Little' is good, 'Alot' ain't better.
T18skyguy
Eugene, OR
Posted: 08/03/08 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
The Mobil 1 filter is a real good filter made by Champion, who also makes filters for aircraft. I'd be surprised if it were defective but anythings possible I guess.
Retired Anesthetist. Pilot with mechanic/inspection ratings.1996 Jayco C 22 foot with 460/Banks Powerpak/Bilsteins.Wife and daughter. Two cats which control my life. 1975 Ford F-250, 84 Coupe Deville, Thorp T18, tons of tools and tons of junk.
