RV.Net Open Roads Forum: Class A Motorhomes: Class 'A' Fridge fire
 > Class 'A' Fridge fire
jolooote
Miami, FL
Posted: 08/03/08 10:28pm Link  |  Quote  |  Print  |  Notify Moderator
I wonder what brand refridge it was.
http://cgi.ebay.com/ebaymotors/2000-40-American-Eagle-Motor-Home-Salvage-Rebuilder_W0QQitemZ180270731011QQihZ008QQcategoryZ50056QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Joe&Charlotte, Nat'l SurfSide DE34D Ford 362HP 5speed
Rusty, Rosie, Snuffy Dogs
Leroy's a Conure
If a 'Little' is good, 'Alot' ain't better.
blucrabbie
Raleigh, NC
Posted: 08/04/08 03:18am Link  |  Quote  |  Print  |  Notify Moderator
clickable link
New 2 us
02 Winnebago Journey 39QD
08 Honda CRV EXL with Blue OX and US Gear Braking System
FMCA #381833
WIT #W137365
Our Blog
Our MAG1CBUS
hubby and i empty nesters
n4gnn n4hon
I Never Look Back, I'm Not Going That Way!
Lug_Nut
Newmarket , Ontario, Canada
Posted: 08/04/08 04:59am Link  |  Quote  |  Print  |  Notify Moderator
I saw one similar in a park I spend time in through the winter. I believe it was a Fleetwood DP. It had been left there unoccupied for a while and just caught on fire. It did not do alot of damage as it was noticed and put out. Fortunitely the park also had keys and could get in and take care of it. I don't know what caused the fire, but expect is was started on the outside at the heater flame.
'07 Newmar Essex 45' ISM 500 4 slides
bsinmich
Holland, MI
Posted: 08/04/08 05:39am Link  |  Quote  |  Print  |  Notify Moderator
It looks like a great opportunity for a neww roof and neww sidewall to eliminate any leaks and delamination problems. For that price you can buy it and make the MH you have always thought should be built.
2003 Newmar Mountain Aire, Workhorse W22, & 2002 PT Cruiser w/Remco lube pump, Falcon 5250, & US Gear Unified Tow Brake
Surf Watcher
Somewhere, USA
Posted: 08/04/08 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
Saw this same kind of fire on a fairly new Dynasty in Miami this past winter. The investigators finally determined it to be from the refrigerator. That unit had a NorCold. The couple who owned the unit were fulltimers and were in it when the fire began. They had a hole burned thru the ceiling, wire bundles melted, lots of smoke and water damage.
wny_pat
Western NYS
Posted: 08/04/08 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
Two to chose from and both have had lots of recalls. Have you checked their web pages for models and serial numbers of the recalled units to see if yours is one of those units
Tsalla Apopka
Pine Ridge, FL
Posted: 08/04/08 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
It would be interesting to know "where" in the fridge the fire started. The back area is vented and sometimes gets mouse or other nests in the area where the heat is generated.
There are also some recalls that could start something in the control panel area.
Denny & Karen
Florida's Beautiful "Nature Coast"
Holiday Rambler Traveler 29' (A TREK in disguise!!)
Brit,TDI,BH & Claire,TDI (Belgian Sheepdogs)
Glady(Morgan Mare - retired),Toes & Beemer(Barn Cats-retired)
WA4OMG (Old Mangy Goat)
jolooote
Miami, FL
Posted: 08/04/08 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
I was wonderin g if it was due to the 'Dometic' recall problem.
wny_pat
Western NYS
Posted: 08/05/08 11:41am Link  |  Quote  |  Print  |  Notify Moderator
But it could have been due to the Norcold recall problem also.
