RV.Net Open Roads Forum: running generator while plugged into shore power
 > running generator while plugged into shore power
DON-B2
WAYLAND, MICHIGAN
Posted: 08/04/08 06:13am Link  |  Quote  |  Print  |  Notify Moderator
is it safe to run the generator while plugged into shore power?? have the unit parked at a rv park for a couple months and want to exercise the generator for about an hour, is it safe to do that while still plugged in or will it be too much power
DON ROBERTS
escaper1
Centerville,Ohio,USA
Posted: 08/04/08 06:15am Link  |  Quote  |  Print  |  Notify Moderator
It should switch back and fourth just fine.
sumerduck8
Virginia
Posted: 08/04/08 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Like escaper1 said....no problem. Your friend Houston
Herewego
Larry Cad drives the ACORN Express!
Posted: 08/04/08 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Before we say it's okay to do, shouldn't we have some idea of what he's running?????
2004 Coachmen Aurora on a FORD V-10 Chassis
2004 Jeep Liberty
Don't take your organs to Heaven. Heaven knows we need them here! Dave has a dog named Muffy and Mike owns a Cockapoo!
Jamesrpm
Oregon Coast
Posted: 08/04/08 06:54am Link  |  Quote  |  Print  |  Notify Moderator
No , all RVs are set up so that they will only operate on one power source at a time. To be super safe one could go turn off the breakers at the power pedestal or unplug from it.
___________________________________________
I plan on living forever , so far , so good
outdoorsman2007
In the Woods - Somewhere!
Posted: 08/04/08 06:55am Link  |  Quote  |  Print  |  Notify Moderator
On a rig that has a generator prewired, it has a transfer switch that won't allow any problems. If he is using a portable generator then his shore power cord is plugged into the genny and not shore power. Either way he is safe.
Belgique
Cedar Island NC (Outer Banks)
My Onan manual says for proper exercise, it should be run under a load (Air Cond and elect hot water heater for instance). It depends on your coach on how you do that.
A lot of coaches don't have a transfer switch and you must unplug from the pedestal and plug it in a receptacle in the coach electrical bay.
The Johnsons (incls a Bouvier, Lab, and Newfie)
Cedar Island, NC (Gateway to the Outbanks)
2008 Winnie Sightseer 35J
Our Mexico trip Blog
Triker33
Homestead, FL
Posted: 08/04/08 07:00am Link  |  Quote  |  Print  |  Notify Moderator
By his other post so far. I would guess he has a older 35' gas MH with a gas Onan generator in it.
If it doesn't have a switch to automatically change it from shore to generator power. Then he will have to unplug from shore power and plug into the generator power outlet to exercise the generator with a load.
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
Banks Powerpack
DataStorm SatMax5 | CoPilot Live 10 | VMSpc | Pressure Pro
14' Chariot Trailer
2001 FXSTI HD
08 HHR LT2
Click here to see where I am
wolfe10
Posted: 08/04/08 07:02am Link  |  Quote  |  Print  |  Notify Moderator
The above information is correct IF the ATS functions 100% as designed.
But how much more work is it to turn of the shore power breaker and/or unplug to make ABSOLUTELY CERTAIN that nothing bad can happen?
Remember, you do not want to start your generator with a 120 VAC load on it so everything you are running should be off anyway. Same (actually even more important) at shutdown.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
Patty98311
Arkansas
Posted: 08/04/08 09:21am Link  |  Quote  |  Print  |  Notify Moderator
One thing to consider is if that ATS switch fails(mine did) you now have a very expensive generator repair. I now turn off the breaker as stated previously because it only takes once and you really wish you had.
