RV.Net Open Roads Forum: Travel Trailers: Awning Won't Latch
 > Awning Won't Latch
irish31790
Reading, OH
Posted: 08/04/08 06:16am Link  |  Quote  |  Print  |  Notify Moderator
The last couple of times out I've had trouble securing my awning when I get ready to close it. One of the arms will not latch at the top. It rolls up fine, but when I try to push the arm flush against the side of the TT, it won't latch at the top. The arm that has the lock on it secures properly but the other arm remains "loose". It hasn't presented a problem while I'm towing, but don't know what the problem is. I've tried lifting on the arm a little, slamming it, nothign works. It's under warrantee so I could have the RV dealer take a look at it, but if it's an easy fix, I'd rather do it myself to save the trip.
Mr. B
Reading, OH
2007 Jayco JayFeather 29X
Reese Dual Cam Sway, WDH, Progidy Brake Controller, McKesh Mirrors
2004 Suburban Z71
'07 Trips: 7, Nights Camping: 22, Miles Logged on TT: 2,010
'08 Trips: 11, Nights Camping: 33, Miles Logged on TT: 2,189
Joy
Henderson KY 42420
Posted: 08/04/08 06:24am Link  |  Quote  |  Print  |  Notify Moderator
I would take it in - sounds as if it maybe got twisted/bent slightly. Have you tried closing that one first thd the working one second? Sometimes that will work but you should still see about it. In the meantime, fasten it as tight as you can with a dog collar or cable tie to be sure it doesn't unfurl while underway.
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Katie-Mini Aussie
Sam-Calico Fat Cat
Maggie-Chihuahua
2003 38'Phaeton DP
2006 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
sljkansas
Miami Co. Kansas
Posted: 08/04/08 06:33am Link  |  Quote  |  Print  |  Notify Moderator
I have found that sometimes when parked on uneven ground that this will happen. I usually will raise the arm up a little to get it to lock in. Another way is to get up on a flat area, and reroll up the awning.
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter in College
Miami CO. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
Hornet28BHDS
Parker, PA
Posted: 08/04/08 07:56am Link  |  Quote  |  Print  |  Notify Moderator
My uncle had the same problem on their JayFeather. The small plastic loop on the top right side of the awning had split. You might want to check that.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
