RV.Net Open Roads Forum: Tech Issues: 12 vdc trouble
 > 12 vdc trouble
Jbird
Illinois
Posted: 08/04/08 09:58am Link  |  Quote  |  Print  |  Notify Moderator
My lead-in 12v positive connection at my fuseboard gets so hot I can't touch the terminal, is scorching the mounting board and threatens a fire. This occurs with any significant load. Does anyone out there have any suggestions as to what to look for? Could this be a bad coach ground??? My power source is two 6v golf carts. My solar control shows normal output from the batteries. The problem occurs when I am not hooked up to 120vac. havent been hooked to 120 so I don't know if I have the problem then as well. I have infrequent web connection so thanks now for any help you can give me!!
36' Travel Supreme Express,Chev 3500 Duramax
robatthelake
Vancouver Island
Posted: 08/04/08 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Sound like the wiring is inadequate for the Load or You Have a Bad Connection!
You Should start by Checking every Connection between the Batteries and the Load Center, Tighten every Screw and Nut.Do this on Both Sides + and - ! Then check the Circuits individually. Remove All the Fuses, making sure that They are Not Over sized. Replace them one by one and check to see if any individual circuit is causing the problem! good Luck!
Rob & Jean 90 Southwind John Deere/Oshkosh/Freightliner Class A Ford 460/ Toad 92 Tracker 2 wd 5sp Convert Still running Great!
" Everything in it"Still" Works"
Jbird
Illinois
Posted: 08/04/08 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Thanks "rob". I should have provided more detail: Problem occurs with different circuits and the wiring is adequate (fiver is now 5 years old and has been fine since new until recently). I have checked and retightened all battery connections.
Could this be some internal problem in my converter even though I'm not hooked up to 120??? Would a bad ground connection cause the heating??
bldrbuck
Boulder, Colorado
Posted: 08/04/08 10:36am Link  |  Quote  |  Print  |  Notify Moderator
In most cases the cause of heat is a poor connection at the point of the heat. I would disconnect that connection carefully clean it, cut back the feed wire about an inch, resolder the board connection, and check all connection between this point and the batteries, cleaning and if there is enough wire reterminating them. Broken strands in the wire maybe the problem. Good luck.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
Wherever I happen to park
Posted: 08/04/08 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Not a bad ground but a bad connection AT THE POINT THAT HIS HOT.
In fact HEAT is often the FIRST indication of a bad connection. (low voltage or no voltage are the other two)
So the bad connection is the one that's burning your fingers
Clean and inspect THAT connection.. You may need to solder the connectors or replace them or clean them or otherwise modify/improve them.
kd8wdave
Middletown,OH
Posted: 08/04/08 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
I^2*R =HEAT , so high current at the connection that is hot pretty well indicates a bad connection (corrosion etc). Other posters are correct, clean the connection good and it wouldn't hurt to put some anti-oxidation grease on it after you get it back together.
cheers
 > 12 vdc trouble
