RV.Net Open Roads Forum: Class A Motorhomes: Dehumidifier for Classd A
 > Dehumidifier for Classd A
ROYBUCK
Chester VA
Posted: 08/04/08 11:42am Link  |  Quote  |  Print  |  Notify Moderator
I have a 39 Ft DP, what size Dehumidifier do I need for this unit I have searched Home Depot the smalest that had was a 25 Pint that drains in a bucket. The Motor Home is parked by my Garage so no problem empty it. Thanks for all help Roy
Roy B Coal Miners Son
USMC Ret
Semper Fi
TMitchell
Punta Gorda, Fl.
Posted: 08/04/08 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
I have been using a 25 pint dehumidifier for the last 4 1/2 years, while my DSDP is parked next to the house in SW Florida. I check it every few days and dump the water, if necessary. I could set it up to drain into the shower, but it works okay the way it is. On the few occasions where the bucket fills up, the unit shuts off, until I dump it.
It is a bit heavy carrying it in and out of the MH between trips
I also have one of the a/c's set at 90 degrees so my 2 satellite receivers don't overheat.
I use a humidity gauge to make sure I don't get the interior too dry.
Tom
Tom,Pat and Buster the Boston Terrier
2004 Dutch Star 3807 Spartan 370HP
Jeep Grand Cherokee
Polishnurse
Schodack, NY
Posted: 08/04/08 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
I think if you check most of the dehumidifier's can be adapted to use a drain hose. Might need to run a hose, but sure beats carrying a pail full of water out every couple days. As long as it's all down hill I would think it would be good to go. JM2Cents Bill.
wolfe10
Posted: 08/04/08 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
Size is not that critical. An accurate humidity setting is. Even a small one will remove moisture fast enough in the small area in an RV and once the moisture is removed, even the smallest units run very little while the coach is in storage(unless doors are opened, etc). But a larger one's only negative is size/weight.
And get one that can sit on the kitchen counter drain into the kitchen sink/gray tank.
BTW, I use an LG LHD45EL which was Consumer Report's "Best Buy" in mid-sized dehumidifiers. We use the mid sized one because when we leave in the winter, I use it in our house. Home Depot has them for $179.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
MGO BLUE
CAPE CORAL FL
Posted: 08/04/08 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Down here in florida we call those things air conditioners............
MGO BLUE
CAPE CORAL FL
Posted: 08/04/08 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
I set my ac at 82 degrees right now its costing me about $15 bucks a month.....but the bus is under cover
cableguy574
North Fort Myers, Fl.
Posted: 08/04/08 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
I leave my roof vends open & put 5 pans of charcoal & coffee in frig. Have not had a problem, once a month I open the door & air out the camper. It is sure nice having the camper parked next to the garage
2006 National Sea Breeze 3860 XL
2004 Honda Element Toad/Brake Buddy
JUST Me & My wife & 3 dogs our pictures
FMCA 387898
A member of NUTS
Gale Hawkins
Murray, KY
Posted: 08/04/08 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
I agree but would add one more negative. For the house I went with a large one in the basement and it makes a lot more noise due to the larger compressor.
25 pints still is 3 gallons a day of water. Yes I know they never do the rated amount unless it is 100 degrees with 100% humidity.
Our 25 pint is hard to hear compared to our 50 pint model.
Phillerup
Fishing, USA <*(((><
Posted: 08/04/08 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
We bought the smaller one that Sears carries and it has worked great for us. We even carry it in the basement ans use it sometimes when on the road - especially in Florida. We also use it for the stick house sometimes. It is pretty quiet, 35 pint, either can drain to an enclosed container or can use a hose and run to a sink or shower drain. It was about 120 bucks when we bought it but now I think it is about 150 on sale.
2003 Newmar DSDP 4005 dual slide king bed Spartan 350 Cummins 2004 Jeep Liberty 4X4 tow, SeaEagle boat in basement
Ames
South Central Florida
Posted: 08/04/08 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
We have used a dehumidifier for over 15 years here in humid FL and find that one you can handle is best as you will be taking it in and out of the coach. We got Sears smallest and it works great in our 40 ft MH. It is less than 400 square feet.
Richard and Babs and a Bob Tail Cat
97 Beaver Patriot 40 Kitchen Slide
330 HP Member FMCA, BAC, Good Sam, CAT RV Club
Toad 04 Durango HEMI
