sjholt
Henderson, NV
You guys are talking about winterizing? In the middle of summer?
Come on- wait a while......
Skip
1996 32' Monaco Windsor DP
Cummins 5.9L 230 HP
5 Airbags in front- 4 in back
brobox
Sunny SW. Florida
I lived in Colorado with below zero temps every winter. The only thing I added pink stuff to was the "P" traps. Blowing the lines and using the MH for weekend ski trips worked great for 20 years. Never had a broken water line or HW heater problem from using compressed air.
Chuck
02 Travel Supreme, 2 street side slides
02 Jeep Liberty Toad
7th Cav
Someplace
I just blow the lines out and use the pink stuff for the p traps. I dump the tanks at the end to make sure that there is no standing water in the dump valve.
7th Cav
2004 Damon Intruder 350
Workhorse W22
1997 Ford Explorer Toad
Bob&Billye
Pueblo West, Colorado(Spring-Fall)Tucson Az(winter
I loved it cableguy. Tis fun to have some humor sometimes. Actually winterizign is used like hurricanizing....but in this case we dont have to flee or tie down our rigs. Have a safe and wonderful journey in life....bob
Bob and Billye
Bairne the dog and Max the cat
Retired USAF
2003 Winnie Journey DL 36
Towing 2007Honda CRV
Raodmaster Falcon 5250 Tow Bar
Brakebuddy Vantage tow brake system
campercajun
Central Texas Hill Country
I used to blow my lines out with 75-100 lbs. of pressure, leaving at least one faucet or valve open at a time, of course (I have a commercial-duty air compressor), even blowing the air out the low point drains, one at a time. Then, on one of our trailers, I decided one winter, after blowing the lines out, to pump antifreeze into the lines to see how hard it would be. I was shocked at the amount of pure water that ran out of each spigot before the antifreeze started flowing at each faucet. I no longer depend on just blowing out the lines; I always winterize now.
My next door neighbor paid the price for not using antifreeze last winter, in a trailer I used to own (the one in which I discovered how much water was still in the lines after blowing them out). Borrowing my air hose, he blew out the lines but did not winterize the trailer with antifreeze last winter.
When he arrived at the campground on their first outing this spring, he hooked up the water supply and turned on the campsite faucet. Since he is hard of hearing, and does not always wear his hearing aid, he was unaware until minutes later, when he noticed water running out the bottom of his trailer, that he had a massive leak. Ice had expanded and pushed a 90 degree fitting completely off the interior water line and cracked the outside shower fixture. The trailer floor was soaked from front to back, water soaked up into the luan on the walls and into wood trim, staining them, and had gotten into the furnace and all the cabinets and bins connected to the floor. The kitchen sink cabinet and countertop were ruined, as was part of the floor.
His insurance company shelled out over $6000 to repair this 25' trailer, after his deductible. The worst part of it was that he was without the trailer for nearly 2 months while it was at the dealer's being repaired, during the best camping time of the year. He sold the trailer to his son after it was repaired, and bought a new one. He has already installed a winterizing kit in it.
RV antifreeze is indeed, cheap insurance.
2003 GMC Sierra Crew HD; 6.0L; Prodigy
2006 Thor Tundra 30RL-DSL; Reese Strait-Line & Dual-cam HP
2001 Honda Elite Scooter
Jim & Gayle Bryant
Murphy's Law: "Anything that CAN happen, WILL."
Bryant's Law: "31 years of RVing? Probably already HAS."
mtrumpet
Hamburg, NY
I do both - blow out all the lines then pump them ALL full of anti-freeze - a LOT of it. I want to be sure that there's no water hiding out in the plumbing over winter. The cost of the Anti-freeze is cheap compared to the time and aggravation of a plumbing repair that I'd have to do.
I know. I had to do it one spring...P.I.T.A.!!
mtrumpet
2000 Southwind Storm 30H
Ford Triton V10 6.8L
F53 Chassis
Davis Tru-Trac
Henderson Rear Trac Bar
Carquest/Moog Steering Damper
Monroe RV Gas Magnums
Goodyear G670 RV's
cordertx
Bedford, TX
You didn't say if you have an ice maker, but of you do, blow out the ice maker water valve as well. Failure to do so can be an expensive mess.
Happy camping.
Larry
jorn
Twin Cities
I forgot the p-traps one winter. I'll never do that again! (Hint: crackitude)
2001 Coachmen Leprechaun 314SS (Acquired in July 2008)
chowchowone
MN, USA
After many years of using the pink stuff I decided to just blow the lines out. Ya sure ya betcha, this spring I had leaks from my leaks. Pink stuff for me here in MN next time.
Lynn
1999 Bounder 34J
F53, V-10
1996 Yamaha Virago 750
427435
Rochester, Mn
chowchowone wrote: After many years of using the pink stuff I decided to just blow the lines out. Ya sure ya betcha, this spring I had leaks from my leaks. Pink stuff for me here in MN next time.
How much pressure were you using and did you only have ONE faucet on at a time (other than when you were changing the faucet/line that you were blowing out)?
Mark
2000 Itasca Suncruiser 35U on a Ford chassis
2003 Ford Explorer toad with US Gear brakes,
ReadyBrute tow bar, and Demco base plate.
