RV.Net Open Roads Forum: Class A Motorhomes: Oil, filter changes DP
 > Oil, filter changes DP
Economical Handyman
S. California
Posted: 08/04/08 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
The oil filter holds a fair amount of oil. So before I remove it, I polk a hole in the bottom and let drain out to avoid spilling it as I remove it.
DeWayne & Judy
04 3810 Dutch Star
ISL 370
Frank's autoformer
01 Sahara Jeep-toad
F 374382
It is hard to kiss the lips at night, that has chewed your butt all day long!
RRRKKK
Quincy IL
Posted: 08/04/08 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Our Wal_Mart has a 5 gal limit. So it may require several trips.
There is a fine line between "hobby" and "mental illness"
Ron K
AeroP
Emery, SD
Posted: 08/05/08 06:36am Link  |  Quote  |  Print  |  Notify Moderator
Get a strap wrench from NAPA. 1/2" drive.
AeroP
AeroP
99DSDP
bldrbuck
Boulder, Colorado
Posted: 08/05/08 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Depending on the location of the filter it may be better to get a filter wrench that fits the bottom of the filter. It will not be as universally useful as a strap wrench but may be easier to use.
The air filter should be at the front or top of the engine and easy to change.
Let us know how it goes changing your own oil.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
Galvanizd
Las Vegas
Posted: 08/05/08 09:08am Link  |  Quote  |  Print  |  Notify Moderator
.......What everybody else said. Its not too tough.
Also, this is at least three beer job One beer to drink right after you finish the work. The other one for you and your buddy as you stand around bragging about how easy/hard the job went. Once you finish you automatically earn the bragging rights.
Clint R.
Roseville, CA
Posted: 08/05/08 09:23am Link  |  Quote  |  Print  |  Notify Moderator
texasbaskets wrote:
2. Use a couple of small oil drain pans, not one big one.
So...with the oil draining out at a fast speed, how do you switch containers with out spilling or splashing oil?
texasbaskets
Frisco, TX
Posted: 08/05/08 11:09am Link  |  Quote  |  Print  |  Notify Moderator
I'm not going to give away all my secrets, but that's why you need item 3 and old clothes, lol.
Michael, Kay, Hans (our Mini-Schnauzer co-pilot) and Prissy (Hans' Malti-Poo co-pilot)
'05 Coachmen SportsCoach SE 372DS a.k.a. "Mana's Cabana"
69RoadRunner
VA
Posted: 08/05/08 11:28am Link  |  Quote  |  Print  |  Notify Moderator
The first time, you have to be fast. Then you replace your drain plug with a Fumoto valve. Open it until the first container is full and then close it. Move in the new container and open the valve.
Lather, rinse, repeat.
I have these on all my vehicles except the Road Runner (not sure which valve fits a Moroso pan) and the MH (haven't changed the oil yet).
09 Newmar Ventana 3942
deandec
El Dorado Hills, CA
Posted: 08/05/08 11:38am Link  |  Quote  |  Print  |  Notify Moderator
In addition to all the above recommendations, I use a large flattened cardboard box under the engine area to catch spills and drips. I do the changes on my concrete driveway. Keep a bag of absorb all or cat litter on hand.
The cardboard also makes it quick and easy to position your drain pan(s)under the engine drain.
Be sure to re-intall drain plug before installing the new oil!!
Hold a ziplock baggie on the filter when removing the oil filter (or fuel filters) to catch any drips.
Transfer the used oil to the gallon containers left over from the new oil to transport the used oil to its destination. Transport the containers in a box to keep them upright.
Dean
95 CC Magna Jeep GC
(Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes.)
great dane
borrego springs ca.usa
Posted: 08/05/08 11:40am Link  |  Quote  |  Print  |  Notify Moderator
After reading all the posts, I fell much better taking mine to my trusted servive facility and watch them do the job while having a cup of coffee and a dougnut JMHO
Great Dane
