RV.Net Open Roads Forum: What is a good truck and ratio for towing?
Search only in Tow Vehicles
 > What is a good truck and ratio for towing?
partsman01
Poco British Columbia
Posted: 08/04/08 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
Good input, I run dual fuel in my truck, I have both gas and propane.
I just figured to get an idea of the minimum so I would not go too small, have been looking at dealers and found used vehicles, one a 1999 DODGE RAM 2500 TRUCK ST 4DR EXT CAB with a 5.9 gas engine and auto trans with 150404 km on it, but they do not seem to want to deal on it.
They did have a 1996 ford with the 460 engine, but appeared to have been in an accident due to the front bumper being in a bit and the box closer to the cab on one side compared to the other, but did not show any major accidents on a check on it.
But passed it up due to not knowing how or what had been damaged.
I figure it is time for a newer truck, but don't want to spend too much, as the wife wants to go a little bigger on the fifth wheel too, so have to have money for both.
P.S. meant to say a fellow at work says just going from a carb to fuel injection will make a big difference, so I gather that alone will make a newer truck a good choice and more efficient than my carb truck.
I also should have asked about a 1/2 ton, like a F-150 or GMC 1500, don't mind if it is a 4X4 but do want an extended cab and long box, like have a full size box and daughter is going to be twelve, so think extended cab will do better for the three of us.
Any down side to 1/2 tons, within say max length of 25 foot fifth wheels.
this is a sticker from current one, so I don't think present unit is that heavy, although the wife loads it up way too much.
* This post was last edited 08/04/08 08:29pm by partsman01 *   View edit history
wilber1
Abbotsford B.C. Canada
Posted: 08/04/08 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
I tow a 10K 5er over the same roads you do with a 2001 Dodge CTD auto. The even with the diesel I wasn't real happy with the 3.55's in the mountains with that weight so I switched to 4.10's. Glad I did. I don't know if that is any help but if you are looking to do a ratio change These Guys do good work. At least they did a few years ago when I had mine done.
"Never trust a man who has not a single redeeming vice" WSC
hpage3
Seabrook,New Hampshire USA
Posted: 08/04/08 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone changed their gears in a 04 Ram 1500 5.7 hemi shortbed quadcab with 3.53 gears and 4x4,auto transmission? I don't know anything about motors,gears... I've been looking at new trucks and the prices are good but trade-ins are low right now so I want to keep mine. The weight of my Rockwood 8314ss trailer is 7543 GVWR,dry wt. 5971,hitch wt.543lbs. I definately know it's there and was thinking about a Ram 2500 but feel that maybe I can improve mine for easier towing. I've heard that even though I use the 4x4 system maybe 5-10 minutes total during the winter, because I have it It will cost me double to go to 4.10? What about my gas consumption better or worse?What would a changeout cost and just how complicated is it?
Howard Page
Seabrook,NH
07 Rockwood 8314SS travel trailer
08 Dodge Ram 2500 Heavy Duty 5.7L Hemi v8 quadcab
Tekonsha Prodigy Brake Controller
SoCalDesertRider
SanDiego, CA, USA
Posted: 08/05/08 01:18am Link  |  Quote  |  Print  |  Notify Moderator
That's a very good old Ford you have there, and it's a supercab too. I would be hesitant to give that up.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
donn0128
Pronounced Ore-gun
Posted: 08/05/08 08:46am Link  |  Quote  |  Print  |  Notify Moderator
The body looks in decent shape. How about a paint job, rebuilt motor and different rear end ratio? Even throwing in new upholstery for the interior and a rebuilt transmission I doubt you would be over about 5000 dollars and the old girl would carry you down the road in comfort for many more years. Lots cheaper than making payments for 5 years on a newer truck.
Donn
BruceStarkey
Ontario, Canada
Posted: 08/05/08 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
Fabguy: Good catch! I didn't pick up on that length thingy Although now that it has been mentioned, there is one fellow with a Volvo 610 towing an under 30' airstream which kinda fits that ballpark. He claims he's getting better mileage with his Volvo than he was with his previous gasser TV.
partsman01: I join others who've said they'd keep that truck. While the 1/2 ton rating would be a concern if you're going heavier on a trailer, you could address that with a rework of the rear axle with deeper gears and those axles were noted for their longevity with the heavy hubs. Find an engine tranny combo from a service vehicle and truck on.
* This post was edited 08/05/08 02:52pm by BruceStarkey *
Today is just the tomorrow you worried about yesterday!
'04' International 4400 LoPro 310Hp/950FtLbs 10Spd Harley/RV Toter
'05' Mobile Suites 38RL3
'01' Harley Ultra in the bike barn.
