RV.Net Open Roads Forum: Toy Haulers: Tahoe 36TB 5th Wheel
Search only in Toy Haulers
 > Tahoe 36TB 5th Wheel
Moomba2002
Sebastopol, CA
Posted: 08/04/08 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Just wondering to get a few opinions. I just looked at a 2003 36 foot Tahoe with a living room slide, garage with a 2nd bed and overall in good shape. Here's the question: it has a salvage title due to when he pulled it out of his driveway it caught on his gate and damaged the left side of the trailer. Lower valance, fuel station box and the reason for the salvage is the rear frame that holds the tail lights is bent out approx. 2-1/2". The rear gate still opens fine and the rest is cosmetic and I can fix. I can pick the trailer up for around $7,000 and I am just wondering if it would be a stupid move to by a salvage title trailer. I was also wondering what the GVW of that trailer was since the sticker is faded and I cannot pick out the numbers. Thanks for any responses.
1999 Ford F350 DRW 4X4 PSD 6spd.
Banks Stinger Package
Fords upgraded Air Intake System
ExtremeAire 150 PSI 100% Duty Cyle on board air w/4gal. tank
Air Bags & Rancho 9000's
2003 Arctic Fox 1150 loaded except solor
DuneJunkie
Rohnert Park, CA.
Posted: 08/04/08 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
If you plan to keep the trailer (since it will not have very much resale value) it sounds like your getting a great buy. I would think for that price if you find any problems you can still get them repaired and not have spent nearly as much as most folks have on a hauler that size.
2005 Chevy 2500HD 4x4 CC Duramax/Allison, with 18K SuperGlide Hitch
2008 385 Fleetwood Gearbox
2005 Yamaha YFZ 450
2002 Honda 400ex
richheck
Modesto, CA
Posted: 08/04/08 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
Moomba2002:
In case you haven't measured that unit yet, I believe it is actually around over 38ft long, the number 36WTB is a model number. The GVWR on that unit was listed as 14,100lbs. Hitch weight was listed as 2,240lbs also.
Hope that helps
Rich
05 Ford F-350 4WD DWD 6.0PSD
05 Wanderer 365 WTB FW
08 Wave 295SLR FW
06 Raptor 700R
04 Suzuki Z-400
00 Yamaha Banshee
07 Kawasaki Mule
Moomba2002
Sebastopol, CA
Posted: 08/05/08 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the information. I probably would keep it as I know the resale would be tough. I am also wondering if replacement parts are available easily for the unit.
DuneJunkie
Rohnert Park, CA.
Posted: 08/05/08 10:08am Link  |  Quote  |  Print  |  Notify Moderator
Not sure about replacement parts for that unit, however, I do know that most items are easily located through an internet search. I presume you could find things for that hauler. Its not that old, and they are fairly commen.
