RV.Net Open Roads Forum: Disconnect toad from Class A's on Marine Hwy??
Open Roads Forum  >  RVing in Canada and Alaska  >  Alaska
 > Disconnect toad from Class A's on Marine Hwy??
lanerd
Ridgecrest, CA
Posted: 08/04/08 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
After Kathy (klm) mentioned about dragging hitch when getting on and off the ferries with Class A's, I began to wonder if disconnecting the toad and driving it on/off by itself would be better. Any comments?
Ron
Ron & Sandie
'08 Safari Simba SBD35
86 Toy 4x4 P/U for Toad.
Tow Bar: Sterling
Brakes: Unified
Toys:
Yamaha 660R Raptor (mine)
Honda 350ES Rancher (hers)
64 Fairlane w/351c - 4sp
Both Fed CS Retirees
Hobbies:
DW's: Quilting
Mine: DW
RETIRED!! How sweet it is....
zigzagrv
Nazareth, PA
Posted: 08/04/08 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
My hitch has skid bars on the bottom. They will/have hit whether toad is attached or not.
Ron
2003 Gulf Stream Ultra Supreme 33'
hwybnb
Posted: 08/04/08 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
It wouldn't make any difference. If the hitch is going to drag it will do so with or without the toad attached. In some ports the ramp angles an be pretty steep at high and low tide, and dragging might occur.
Rocky2
Ventura, Ca.
Posted: 08/05/08 07:24am Link  |  Quote  |  Print  |  Notify Moderator
Disconnect the toad to save money! You are paying for the extra 3 feet of tow bar and not getting the advantage of the driver rate. It is also easier to get the vehicles on and off the ferry.
Rosher
Tyler, Texas
Posted: 08/05/08 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with Rocky2 above. Save money by disconnecting. That's what we did when we came back via ferry. Even better reason for disconnecting is that it's easier to maneuver on the car deck when you don't have to worry about the toad. Also the parking crews prefer that you disconnect, at least that's what they told me.
Allegro 32 BA
Jeep Liberty Toad
Buster, 3 lb. Yorkie
driveby
Vancouver BC Canada
Posted: 08/05/08 10:09pm Link  |  Quote  |  Print  |  Notify Moderator
Having been off many a BC Ferry I'd say I'd drag regardless and the hassle of unhooking isn't worth it. Just go slow and alot of the deckhands will give you an OK or stop if you're going to hit. Never hit yet. I've wondered a few times but never actually scraped.
2008 Itasca Sunova 35J Class A
1997 TJ Sahara, hard and soft tops and AC
Held together via Roadmaster Falcon 2 tow bar and stopped by US Gear Unified Brake system.
Citizen Eric
Eagle River, Alaska, USA
Posted: 08/12/08 01:01am Link  |  Quote  |  Print  |  Notify Moderator
LANerd,
Forget the toad. Just bring lots of good food to eat. I hear the Ferry's not like the Love Boat. Just a big floating bus with spendy snack bar food.
Good luck and safe travels home.
Eric
Eagle River, Alaska
U.S. Air Force (retired)
2005 Keystone Cougar 304BHS travel trailer
2008 Ram 2500 Mega Cab w/Cummins 6.7L and 6-speed automatic
robanddi
Burton TX USA
Posted: 08/12/08 10:22am Link  |  Quote  |  Print  |  Notify Moderator
Some of the smaller ferries (Prince William Sound) requires that you detoad (or at least that is what they told us). Example: DP had to be backed off ferry from Cordova to Whittier.
I believe we also had to do this between Skagway and Haines in years past.
Diann
Robert & Diann
2001 34' Foretravel U270
2004 Avalanche
Burton TX
Hjudge49
St. Augustine, Fl.
Posted: 08/12/08 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a ferry service from Seward, Whittier or Homer to Prince RUpert that will take a big rig?
UsNtheBus
Calgary, Canada
Posted: 08/12/08 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
I asked the same question of BC Ferries a couple of years ago. You're right about saving money BUT, if you disconnect, the car and the motor home go into different lineups. If it's busy, there's a chance you both might not get boarded on the same ferry.
At least that's what they told me.
...Graham
