RV.Net Open Roads Forum: Tech Issues: What won't Eternabond stick to?
 > What won't Eternabond stick to?
bdpreece
Woodburn Oregon
Posted: 08/04/08 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
The topic says it all if everything is clean and dry; What won't Eternabond stick to? I have a front roof seam that was leaking during the rainy season and I used roof patch on it . Temp fix worked but now I have purchased some Eternabond tape and want to do it right. Do I have to strip everything or just clean and put down the tape?
Brian & Loretta
Chance (Golden Retriever)
2004 National Tropi-Cal T396
2005 Suzuki XL-7 toad
We moved!! No more nasty neighbors, no more rotten parking. I am saving this picture just to remind myself how bad it was.
OnaQuest
Raleigh, NC
Posted: 08/04/08 11:21pm Link  |  Quote  |  Print  |  Notify Moderator
Eternabond will not adhere well to silicone caulk. Clean as much of that off as possible. Overlap what you can't remove and you will be okay.
Dyslexics of the world... UNTIE Visit www.Dyslexics.moc
joanne0012
Boston, MA
Posted: 08/05/08 06:24am Link  |  Quote  |  Print  |  Notify Moderator
You're supposed to overlap the caulk anyway, in case an edge deteriorates.
The only other thing Eternabond won't stick to is whatever they make the peel-off liner paper out of.
Joanne
1994 Lazy Daze 23.5' TK
mike4947
N. Syracuse, NY
Posted: 08/05/08 06:40am Link  |  Quote  |  Print  |  Notify Moderator
What we've found won't allow Eternabond to adhere properly has been moisture, silicone caulk/spray, extreme compound curved surfaqces that won't allow enough stretch to prevent wrinkling, and just plain old dirt/crud.
We also like using a $1.99 wallpaper roller to go over the surface to make sure no air bubbles and that the tape actually makes contact with the surface.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
OzarkPreacher
S.W.Mo. God's Country
Posted: 08/05/08 06:46am Link  |  Quote  |  Print  |  Notify Moderator
I have found the above to be true also. We also use the roller to make sure it is making good contact. I have never had an eternabond fix to leak.
mooreadventures
North Carolina
Posted: 08/05/08 07:42am Link  |  Quote  |  Print  |  Notify Moderator
I've always removed the old caulk to the point I have a smooth surface, then clean it up with some mineral spirits or paint thinner and apply it. A roller definately helps, but I've done it with and without one - without one, you'll really wear out your finger tips... trust me. You want to make sure you have about a 2 inch overlap to ensure a good seal.
I use Eternbond Tape on anythign the sticks up thru the roof (vents, skylights) and the end caps, then I Dicor on the sidewalls (when the roof meets the top of the wall) and silicone on the windows and lights (anywhere I need verticle sealant - Dicor doesn't work vertically).
Mark & Tammy
'01 Excursion Limited, 4x4, V10, RoadMaster Active Suspension
'01 Prowler 31G
Equal-i-zer Hitch - Prodigy Brake Controller
Dave H M
IL
Posted: 08/05/08 07:55am Link  |  Quote  |  Print  |  Notify Moderator
just a thought on dicor not working on vertical surfaces.
Dicor comes in the non self leveling variety (how bout that)
One of the local RV dealers stocks it here.
It works for me.
Admiral
Lodi, Ohio
Posted: 08/05/08 09:53am Link  |  Quote  |  Print  |  Notify Moderator
Teflon....Pam.....non-stick foil.
That stuff may be good replacement for hot wax hair removal.
2004 Damon Daybreak 2960F
05 Honda Element LX
In a democracy two wolves and a sheep can vote on what to have for dinner.
mooreadventures
North Carolina
Posted: 08/05/08 11:09am Link  |  Quote  |  Print  |  Notify Moderator
It works for me.
Don't think I've seen it. Sillicone works just fine and I can get locally just about anywhere.
Thanks for the idea though.
Wherever I happen to park
Posted: 08/05/08 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Well the peal off liner is siliconized (so it's silicon)
Murphy's law says there are two lists of things re Eternabond (or anything else for that matter) sticking to
1: The list of things it will stick to
2: The list of things you want it to stick to
And the two lists are exclusive of each other
Eternabond never hired Murphy though so they don't follow his law
