RV.Net Open Roads Forum: Toy Haulers: WW Mod Your Couch?
Search only in Toy Haulers
 > WW Mod Your Couch?
Hap Hazard
Mammoth Lakes
Posted: 08/11/08 11:37pm Link  |  Quote  |  Print  |  Notify Moderator
After reading this post I went out and did my mod (about 30-45 minutes to complete and less than $10.00). It has been a concern of mine for sometime but I didn't take action because I thought I was just worrying to much. After all, no one else had appeared to have had a problem. This post changed my mine.
I didn't worry about locating a stud. I used the bottom flat plate on the upper bunk frame, just above the corner of the window. I know it is securely attached to the trailer frame. I simply drilled a hole in the flat plate that gussets the two vertical rails. I countersank the head of a beveled screw to fit flush with the plate so there would be no stress placed on the nylon block of the bunk when in the down position. I then bolted a hook under this plate.
I then used 1/4" plastic covered cable to run down the front of the sofa to the second (lower) leg. There I crimped a wire terminal to the cable. The terminal was bolted to the center hole in the metal frame of the leg mounting plate. I had to counter sink the screw head where it was between the leg mounting plate and the wood seat.
The upper end of the cable was looped and crimped at the top.
This system stays attached at the lower leg and simply hangs under the sofa when the sofa is in the down and set up position. When you fold up the sofa for travel, you simply hook the looped end of the cable on to the hook. This cable will never support a lot of weight as it is there as a back-up, but it is tight enough to provide some support.
Hap
BensBox
Gilroy CA
Posted: 08/12/08 08:34am Link  |  Quote  |  Print  |  Notify Moderator
How about a picture Hap?
Ben
2006 Weekend Warrior LE3305, Billet Edition
2005' KFX 80 (Kid 1 or 2)
(RZR Wanted for wife & other kid)
(still deciding on what I want)
06' F350 4X4 Tow Boss to pull it...Nuff Said
Reese Signature Series 18K Hitch
Ride Rite Air-Bags
Hap Hazard
Mammoth Lakes
Posted: 08/12/08 10:18pm Link  |  Quote  |  Print  |  Notify Moderator
BensBox
I'd love to attach photos, however, I've not had much luck doing so. Can you explain exactly how to do it?
Hap
Bansheezz
So. Cal.
Posted: 08/12/08 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
pcassidy111 wrote:
Bansheezz wrote:
This is what I did :
Where did you get the hardware? Is it stainless steel? I want to make this upgrade to my couch. I cannot find a stud on the other side of the couch that is close to it so I may add a second strap a foot or so below the WW installed one.
I got everything from Home Depot. The hardware is chrome plated not stainless. I located a stud in the wall, thats where the eye bolt is.
06 GMC 2500HD 4X4 CC DMax 4" Rancho Lift, M/T Tires & Wheels, TTS 4" cat-back, Mag Hytec diff. cover, Super Springs. PPE Airbox Mod.
1400 lbs. Equalizer WD Hitch, Prodigy Controller.
06 WW FB3000
02 WR250F , 01 Banshee , 85 ATC 250R
aSa Supporting Member
Bansheezz
So. Cal.
Posted: 08/12/08 10:46pm Link  |  Quote  |  Print  |  Notify Moderator
Hap Hazard wrote:
BensBox
Hap
Hap, creat a account at http://photobucket.com/
Up load ur pics there. Pick out the pics u want to display here, copy the direct link under that pic. Click on the image icon here and paste the direct link. You'll have to play with the size to see what fits best.
