Brockc
SC
How hot should the wheels get while towing? Sometimes my TT wheels get extremely hot; to the point of not being able to touch them for more than a second.
It's around the lug nuts and a few inches outward.
Just put Maxxis tires on and don't think I'm overloaded weight wise.
Is this normal?
Cabriolet86
Rochester, MN
Heat on the center of the wheel could be bad wheel bearings.
Polishnurse
Schodack, NY
Sounds like you might want to check them out. If all the wheels are getting hot like that, it could be a brake problem. Are you sure your control is set up right. You shouldn't be that hot unless you have been braking a lot. Like driving the Skyline. Do you smell anything like brakes. JM2Cents Bill
tvman44
Southwest Louisiana
A lot of heavy braking will produce a lot of heat.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
SPRey
Orange County, Kalifornia
No heat on my tires--even when driving through Mojave desert at 107 degree temps. I drive with the flow of traffic (65+) and I swapped out my Marathon ST tires (LRC) for WranglerHT LT tires (LRD) earlier this year.
I do recall getting heat from the Marathons...but nothing from the WranglerHTs.
Tim & Sue
Gerry (GSD) & Jammer (Sheltie)
2005 F150 4x4 Lariat 5.4L 3.73 Please buy a Hybrid...I need your gas for my 37 gallon tank!
2000 Nash 19B...comfortably pimped with a real Queen Size Bed
Red Wine anyone?
Brockc
SC
Bearings are fine and also greased well. The TT is a 2006 with probably only 4000 miles on it.
Could it be caused by lug nuts that may be torqued too tight?
Also, could it be the brake controller set too aggressively? I feel like the TT brakes bite too hard when applying the brakes, but when adjusting them on a flat level surface with the hand control, they seem to be set where they need to be?
How much should you feel the TT brakes inside the TV? Right now, when applied there is a distinct "bite" but they don't seem or appear to be locking up.
reno82
Cardiff by the Sea, CA
Sounds like they may be too tight. I know there is a fine line with my adjustment where I don't feel the "bite", but do feel the trailer grab just before the truck, it feels really smooth, sort of like a drag on the truck then the truck joining in.
hotpepperkid
Chino Hills CA
Trip out in July 102 deg notice the left side warmer than the right 10 to 15 deg.
hpk
2000 Ford F-350 SRW 4X4 PSD Jayco Super Lite 29.5RKS 5th wheel 50 gal X-ferflow in the bed tank. Banks big exhaust and Stinger kit.
cujo1950
victorville, ca.
checked mine on a recent trip across the desert towing 9500# 5th wheel , outside temp. was over 100, my tires, michelin xp ribs, got as high as 140 deg. had no problems. Using an infra red gun to check, my buddies were about the same.
2006 Dodge 2500 CTD, Auto
2006 Pilgrim 295RLSS fifth wheel
fpresto
Maryland
Not being able to touch them for more than a second is purely subjective. What may be hot to someone may not be that hot to someone else. Before taking any drastic action purchase a cheap infrared thermometer and find out what you are dealing with.
USN Retired
2007 Cedar Creek 30 RLSTS
2008 F350, DRW, V-10, B&W hitch,
Pressure Pro, JT Strongarms
