RV.Net Open Roads Forum: Class C Motorhomes: Bigfoot 30MH27DSL question
 > Bigfoot 30MH27DSL question
FedAgent
Corpus Christi, TX
Posted: 08/05/08 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
My buddy just purchased a used 2004 Bigfoot coach from it's second owner. Very nice coach with low mileage, 13,000. The last owner apparently after a trip from California to Texas and one other trip, did not know or care to dump the black and gray tanks. After undertaking that pleasant job, we were going to dump and sanitize the fresh water tank. We looked in every compartment and crawled under the rig looking for it, all without success. Any of you Bigfoot owners have any idea where the fresh water tank dump valve is on this model? The manual talks of how to sanitize the tank and mentions opening the dump valve, but fails to mention where it is.
Thanks,
Larry
Larry
2007 Lazy Daze, 26.5 MB 05 Jeep Wrangler toad
garyhaupt
Kitimat, BC, Canada, Mile '0' of Alaska HiWay #37
Posted: 08/05/08 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
I am wondering...is there a lower cabinet? Like..under a closet or drawers? If so...you are looking for a simple plastic line, poking down, thru the floor with a valve on it. It's at floor level, maybe tucked into a corner.
Gary Haupt
flibmeister
Gold Canyon, Arizona
Posted: 08/05/08 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
On my '03 29SL, the fresh water tank is located on the floor of the coach, behind the headboard of the bed, and all the piping (bypass valve, drain valve, etc.) can be accessed by removing the drawers on the driver's side of the bed.
cochalet
Colorado
Posted: 08/05/08 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
You might want to look under the dinette again. I haven't had occasion to access the drain in my recently purchased used 2005, but I thought I recalled reading somewhere that it was located there in my model (29RQ). There are no tanks under the rear bed in that model.
K.T.
2005 Bigfoot Class C
2004 Scamp 19
aeejbe
Van Nuys, CA
Posted: 08/05/08 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
My little suggestion for pinpointing the whereabouts of that fresh-water drainage would be to crawl underneath & look for a clear plastic tube sticking down from above. Ours happens to be located under the rear dinette seat on the street side. But the 29G is 'a whole different animal' from his double slide unit. Ask your buddy to consider joining us here for more "expert" advice.
A
30MH29G
visch1
CAPE COD, MA
Posted: 08/06/08 06:43am Link  |  Quote  |  Print  |  Notify Moderator
In my ’06 29G the pump and drain access is located about 6 feet in back of the driver in the storage compartment. It has 2 small doors for access, 1 for pump, other for drain which takes hours it seems.
kendall69
Palm Springs California
Posted: 08/06/08 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Under he seat for the dinette, there is a trap door.
2002 - Bigfoot M-29G, 2004 Jeep Rubicon Toad
FedAgent
Corpus Christi, TX
Posted: 08/10/08 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
We finally found it! It is located inside the rig, in the bedroom, under the hanging cloths closet. The unit has a winterizing cutoff valve, and about an inch behind that is the fresh water tank drain valve. If you stand on your head in the bedroom and have a good flashlight, long arms and skinny fingers, it is a piece of cake to find and use. I like the coach, seems high in quality, but that drain valve could use some more engineering.
Thanks for all of the suggestions!
Larry
melmar
Burleson, Tx
Posted: 08/11/08 06:47am Link  |  Quote  |  Print  |  Notify Moderator
Next time try opening your water sigots inside the coach. You may a vaccuum problem that prevents the water from draining correctly.
2004 Minnie 31C
2007 Honda CR-V Toad
2005 Nissan 350Z Toy
2 Mini Schnauzers, Ernie and Misty
