onlemon
Temecula, California
Anyone help me choose batteries for my 32' 5th wheel toy-hauler? There are so many to choose from and every time I talk to someone new they tell me something different. HELP!!!!
Been Everywhere
Tomball, TX
I like Optimas myself, no acid to worry about spilling. Been running them in my diesel pickups for years.
Daniel & Ms Kitty the cat
2003 Hitchhiker II 30.5 RLBG Full timer since it was new.
2003 Chevy 2500HD D/A w/ air foil, sprayed bedliner, 36gal transfer tank, 195k miles
1996 GMC 2500HD 6.5TD, sprayed bedliner, 338k miles
onlemon
I am referring to the batteries mounted in the 5th wheel. I have been researching golf cart batteries. Any suggestions.
Okie on the road
Tuttle Oklahoma
I have two 6V golf cart batteries hooked up in series for 12V. That seems to be a fairly common hook up and works well. The batteries last a good while when maintained.
Okie
traveln_circus
Wa.state
Sam's Club has them for under 70.00 a for 6 volt Golf Cart battery. Trojan also make a good 6 volt.
2004 cardinal 33 LX 2000 Ford F350 crew cab PSD.
Smith & Wesson M&P .40 and a Rottweiler.
Been Everywhere
Tomball, TX
onlemon wrote: I am referring to the batteries mounted in the 5th wheel. I have been researching golf cart batteries. Any suggestions.
That's what I'm talking about too, Optima makes a deep cycle and a marine battery, which can be used in an RV.
traveln_circus
Wa.state
IMO Optima is a ok battery but way over priced for what it does.Optimas fall on there face in amp hours. You can get two 6 volts for the price of one optima. That will give you over 2x the amp hours. Optimas look cool but I keep my battery compartment closed.
doughere
Mooresville NC
I think any pair of 6 Volt GC batteries will do. Trojans are considered the gold standard, but they are spendy. Any of the true GC batteries should be fine.
I would suggest that you insure your converter is a good 3 stage, capable of keeping your batteries up to snuff. If not, even a good set of batteries will disappoint you. I have a Prgressiv Dynamics PD9245 that I am happy with; I got the 45 AMP unit as I wanted to be able to use a 1KW gen for charging. If you are planning to charge from a larger generator or shore power, I suspect a 60 AMP unit would be better. There are many other good converters that others have found work well.
Doug
Chefd
Arizona
I have 4 6V GC. I just replaced the factory original after 6 years. I went to NAPA paid under $300. I also have a solar panel connected to the bat.
Chefd
porky
New Baltimore, Michigan
We went the 2 golf cart battery route with our 30' Seahawk but since our Yellowstone purchase have just stuck with the single battery. We always keep the battery at home on a trickle charger if the unit sits in our storage lot longer than a few weeks. I think 2 batteries are an over-kill for anyone who doesn't drycamp a lot. Good luck.
Jim & Marlene
01 Silverado 3500 gas
07 Yellowstone 34' FLR
