RV.Net Open Roads Forum: Truck Campers: Hyki Hatch
 > Hyki Hatch
Gary3
Windsor, ON
Posted: 08/05/08 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
Here I go again has anyone with a newer Lance come up with a outside cover for that heat source,there doesn't seem to be any place to attach something.The cover from the UK would be to much money I'm almost thinking of taking sewing lesson's and making my own.
Gary  Lance  1181 solar Gen.
CTD
Stockton, CA, USA
Posted: 08/05/08 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
We've got the same vent on a 2005 1191. The design makes it difficult to attach anything on the exterior. I would like to know as well. Awhile back I had the misfortune of the handles ripping off in a strong wind letting the clear dome fly open. That did a job on the pleated night shade which was time consumming to replace. Be warned a replacement shade (just the shade) is $260 list and I got it for the "bargain" price of $172 from a dealer. I was told there are new handles in the design stage to be replacing the existing ones that fail. For what the thing costs and the cost of the camper, those should be free replacement.
1996 Dodge 3500 4X4 Dually Gear Vendors OD 1996 Alpenlite 29RK
WX2G
Central Florida
Posted: 08/05/08 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
I have same hatch on my Lance, and have been using a piece of aluminum faced bubble type insulation, similar to that found in windshield sunblockers on the inside of the hatch.I leave the screen open. Product is available at big box stores, about 3/8 inch thick, aluminum faced both sides, flexible.
I put this in place and use a small dowel in the track to support the center, and it catches the edge of the screen track.. The piece is not quite big enough to completely cover the area, on purpose, since I didn't want to trap heat up there. The aluminum reflects heat out pretty well, it makes a big difference.
This has been in place for 3 years, most of the time,including traveling and always during storage here in Florida. I can see no ill effects on anything,
RenoAl
Reno, NV
Posted: 08/05/08 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
Aluminum foil and bungee cords. Doesn't work when moving.
Good luck and good camping
2005 Dodge 3500 DRW:Firestone air bags w/ in dual cab control, Rancho 9000, Helwig sway bar, 55 gal fuel tank, cold air box
2005 Lance 1191: generator, TV, A/C, solar
Bayliner 19.5 Capri & 12 ft. Gregor
1965 TBird
Rosie the dog
Gary3
Windsor, ON
Posted: 08/06/08 04:32am Link  |  Quote  |  Print  |  Notify Moderator
Well I think the bubblefoil on the inside sounds good,so its off to I would think homedopot or Lowes should have it. I did use it before in the skylight of my last camper but there was no handle in the way.Thanks for the reply
oklamtnbkr
SouthWestern ,Oklahoma
Posted: 08/20/08 06:13am Link  |  Quote  |  Print  |  Notify Moderator
I use the foil-bubble stuff and used velcro tabs to keep in place,cut it large and place the tabs on the inside plastic area
2006 GMC 4X4 CC DM/A 6spd DRW Timbren's on all 4 corners, Rancho's Torklift's,Fastguns 2004 BigFoot 30.11SL
CTD
Stockton, CA, USA
Posted: 08/20/08 10:49am Link  |  Quote  |  Print  |  Notify Moderator
Have you ever noticed how hot it gets on the underside of the dome when the night shade is closed? It makes a great solar oven! I was amazed at the heat generated, it's a wonder it doesn't melt.
rjsurfer
North Carolina
Posted: 08/21/08 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Here is a similar question, on my fiver they have a large plastic dome over the shower for extra headroom and light but it lets too much light in and way too much heat.
Rather than putting a shade across on the inside as others have suggested I'd rather just paint the clear plastic dome on the outside, black would make it too dark, any suggestions on a color or type of paint/coating to use?
And is there anything (paint or coating) that could be removed when it came time to sell?
Ron W.
03 Dodge 2500 SRW,SB,EC
2008 Keystone Cougar 245RKS 5th Wheel
DRZ-400SM
DL-650
SoCalDesertRider
SanDiego, CA, USA
Posted: 08/21/08 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
I vote for white.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
rjsurfer
North Carolina
Posted: 08/22/08 06:18am Link  |  Quote  |  Print  |  Notify Moderator
That's what I was thinking too, white would let some light in still keep the temps down.
Ron W.
 > Hyki Hatch
