RV.Net Open Roads Forum: Truck Campers: Removing Lance Fresh Water Tank
 > Removing Lance Fresh Water Tank
DanAKAL
Alaska
Posted: 08/05/08 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone removed their fresh water tank? I have a 1995 Lance 945 and consistently getting water on the inside floor near the fresh water tank. I suppose it has a leak and I am trying to remove it to see where it might be and what I can do about it. So far I haven't had much luck getting the bulkhead in front of the tank out as it looks like it will have to come out to remove the tank. Anyone got any words of wisdom for removing this tank to fix what seems like a leak.
Dan
2002 Dodge CTD - Duelly
1995 Lance 945 - Hope It Is Half As Tough As My Cameo Was
1990 Dodge Ram W250 - SOLD! Could Make A Hemi Shimmy!
1987 Cameo 9 ft TC - SOLD! One Tough TC!
fast.5
Ontario, Canada
Posted: 08/05/08 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
Hi: I would check to see if the fill pipe is properly connected at the out side wall as well as the vent tube. If you feel in your carpet area above the tank you should find screws that will allow you to remove the top and look for the leak. Never had the bulk head out.
Mike
2004 FORD F350 Supercrew 4x4 V10 Airlift incab controls 42" titan extension camera.
2004 LANCE 1161 Loaded, Air, fan, Dicor and all weather packages Awning&Slide awning 50W solar 36lp Plus Generac
Fast.5 Reno Page http://community.webshots.com/user/fast5
DanAKAL
Alaska
Posted: 08/05/08 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
If the fill ppipe and vent at the outside were leaking wouldn't I see water in the cabinet/sink area? The carpet and step area had no water. What I kept finding was water on the right side floor near the refrigerator. I have cut up pieces of carpet that I laid on the floor in my TC. The entire piece of carpet in front of the water tank was dripping wet. I just gotta believe there is a leak in the tank somewhere. I have the lid/carpet area off the top of the tank. It's the bulkhead in front of the tank that is causing me grief.
Dan
Redrattler01
Oregon USA
Posted: 08/05/08 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure its not a leak from the slider window? Might look at "Netboys" page for more info on your tank...
2001 F-350 SRW CC PSD, '03 Lance 1010 Rancho RSX9000
Hey there
Pendergrass, GA
Posted: 08/05/08 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Hi DanAKAL,
There is a plastic tube connected to the bottom of the tank to drain the tank. It is possible that this has somehow started to leak at the connection.
Kurt
2001 Silverado 3500 DRW CC LB 6.0
1993 Lance Squire Lite 150 (8'6")
2001 Fleetwood Caribou 11J (11'6")
DanAKAL
Alaska
Posted: 08/05/08 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
Well it's finally out. I do not recommend doing this unless it is ABSOLUTELY NECESSARY! Which was my case. The problem was the pump suction connector on the bottom of the tank and a crack along one of the side seams. Based on what I found under the tank this has been leaking a very long time. Maybe since the camper was built. It was very difficult and required some ugly tools and oil field hand determination. The bulkhead is a total loss. If not from me removing it just the wood rot. FWIW there are some blind screws in the bulkhead that are just nearly impossible to find. This is where that determination part came in. I'll have to bulid a new bulkhead after getting a new tank. One of my friends is a welder that specializes in aluminum so I'll probably get him to build me a tank. These things were never meant to be removed and it takes almost a wrecking crew to get it done. I'll have my camper back togetrher soon but it doesn't look so good right now.
Dan
Camp, Forrest, Camp!
Boise, ID
Posted: 08/06/08 08:18am Link  |  Quote  |  Print  |  Notify Moderator
Your instincts were right. Since you have this chance to craft your own bulkhead, you should do something cool like built in storage, a step, recycle bins, etc.
-2000 Chevy K3500 CC DRW. 7.4L, Auto, 1985 Lance 900, 1999 Bayliner Capri 1800LS Outboard
-Air Lift bags, Torklift tie-downs, Superhitch w/48", Rancho RS9000X, K&N FIPK, MagnaFlow exhaust, Hypertech.
petekerwien
Camano Island, WA
Posted: 08/06/08 09:39am Link  |  Quote  |  Print  |  Notify Moderator
If you could, a couple of photos would be interesting. Thanks.
DanAKAL
Alaska
Posted: 08/06/08 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
I'll work on some pics, especially as I go back together. My bulkhead had a fold up step and one of the things I am considering is eliminating this step as I never fold it out to use it. Do you guys use a step here? HAven't decided yet about a new tank I may fix this one but you can bet it will be hydro tested and hold water without a drop loeaked for at least 48 hours beofre I go back with it.
Dan
Hey there
Pendergrass, GA
Posted: 08/06/08 11:27pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Dan,
In my Fleetwood, the water tank is in the bulkhead. It has never leaked; but I have opened the bulkhead twice to check on it. (6 screws) I am contemplating making the top to the bulkhead easier to remove.
Kurt
