RV.Net Open Roads Forum: Beginning RVing: slide out & gen.
 > slide out & gen.
rdy2gocusa
jonesboro ga.
Posted: 08/05/08 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
I was told to not use the gen. to put slides out. Should batteries be used to put slides out?
rv2go
Somewhere between Knoxville, TN and the coast.
Posted: 08/05/08 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
I use the batteries to put the slide out on the MH. If you are concerned about draining the batteries, I see no reason that you can not use the gen. Come to think about it, I probably have.
Winnebago Journey
TN Lic. RV 2 GO
1995 2dr. Hard Top Geo Tracker
www.rv2go.us
I'm here #4335
Travel Photos
Mandalay Parr
Phoenix, AZ
Posted: 08/05/08 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
I always use the gen or shore power to run the slides. It is a big drain on the batteries
* This post was edited 08/05/08 06:57pm by Mandalay Parr *
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
602-321-8141
tvman44
Southwest Louisiana
Posted: 08/05/08 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Wether the ginny is running or not you are pulling power from the battery. The convertor with the ginny running is just raising the voltage a little which is better for the slide motor than low voltage.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
johnthecamper
Grapevine, Texas
Posted: 08/05/08 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
I always use the generator or shore power to operate slide. Either way the battery is the primary source but having power from converter charge helps keep the voltage up.
08 F250, 08 Jayco 29D
dbbls
Missouri
Posted: 08/05/08 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
As long as you do not disconnect the batteries they will be used to operate the slide. I suspect what you were told is to not disconnect the battery and use the generator only. This puts a extreme load on the converter.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
Dogbone
Ontario Canada
Posted: 08/05/08 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto, I usually start the gennie or plug into shore power before operating the slideouts, I also start the MH before lowering my jacks.
2006 Holiday Rambler Vacationer 35SBD
36ft Workhorse 8.1
Mr Steve
Glendora, CA
Posted: 08/06/08 08:14am Link  |  Quote  |  Print  |  Notify Moderator
When I purchased my motor home the dealer told me the best option was to always start the motor home engine prior to moving slides or jacks. I'm sure generator is just as good, but I always just start the engine.
Wherever I happen to park
Posted: 08/06/08 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
The only problems I see in using the generator to move slides in and out are
1: While the slides are "Between states" Generator exhaust may seep in via the gaps in the seals.. This should not normally be enough to cause issues as the slides do not spend that much time "Between States" (Between in and out)
2: The sound of the generator could mask "Trouble Sounds" in the slide system
3: Overload of a cheap converter (not a problem with my PD 9180 + Wizard)
 > slide out & gen.
