CPC
San Fernando Valley, USA
We have a 2002 Chevy 2500 with the 6L engine and the 4.10 rear end. We have the towing package so the truck has a transmission cooler, but when we haul thru the mountains or up any long grade the transmission temperature eventually gets up to the red warning area. Our trailer weighs about 8k lbs. when fully loaded and the truck is rated to tow 10.4K lbs. so there is no problem with over loading. I have a friend that says I should not put a second cooler on the truck. I am concerned about the transmission fluid getting hot so often. Is there a problem with adding a second cooler in line with the current one?
local temperature
Our Pics.
Ductape
On the Road
I think you have something wrong with your truck... had the same truck and similar trailer all over the Rockies. Never saw that. GM HD trucks in general are very well cooled.
Is your torque converter clutch locking up?
I think you need to look for the cause and don't just treat the symptom.
Surveyor SV-234 >Equalizer> H3
Previously a fiver crew.
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Try changing your transmission fluid with a synthetic first. Synthetics resist high temperature degradation, keeping your tranny from forming varnish deposits and losing efficiency. You should have the tranny professionally flushed first. That by itself may solve the issue. If you decide to go with replacing the cooler, change out the old one with one bigger trans cooler, instead of adding the complexity of 2.
Engineer9860
Eagle Scout dad
I know this is a dumb sounding question, but I have learned to never overlook the obvious.
Are you using the Tow/Haul mode? If not you should be.
2002 Chevy 2500HD 4x4 8.1/ZF6sp RC/LB
2001 Chevy 2500HD 4x4 6.0/4L80E EC/SB
1997 Chevy Blazer 4x4
1994 Chevy K-2500 4x4 C6P 5.7/4L80E
1979 Chevy K-30 4x4 4sp 4.10
1977 Chevy K-30 4x4 4sp 4.10 454
30 year student of the Boeing B-17 Flying Fortress
CPC
Engineer9860, thanks for the reply. I always use the tow/haul mode. All it does however is change the shift points and much of the time when I'm towing in the mountains I'm in second gear.
Thanks to the other replys also. I think that I'm going to take the truck in to my mechanic and have him check it out.
skipnchar
Topeka Kansas USA
Putting in synthetic fluid will NOT solve your problem with overheating but it CAN make the transmission stand up longer to the abuse. I'd find out WHY it's overheating and work on the problem from THAT standpoint first. If you have a leak in your roof it can ruin your floor and fixing the floor won't have any effect on the roof leak.
CharlyG
West HIlls, Ca.
Actually it does. Within days of the floor bring finished, another deluge will come along, ruining the floor yet again!
1998 Chevy C2500HD Silverado ECLB 75,000 miles 5.7L Vortec 4L80E 3.73 Posi 8600# GVWR
2004 Fleetwood Caravan 25S 6000# GVWR
thebudman
Reno, NV
OK-- so are you saying that an auto tranny that is overheating will cause the roof on your house to leak?
08 Dodge Ram 3500 Mega Cab 6 sp manual
08 WW FK 2100
08 Rhino
99 Honda TRX 400
08 Yamaha TT50
9-11: Never Forget!!!
If you have the urge to fly your country's flag, then go do it on your native soil.
PaulJ2
Northwest Oregon
Sounds like torque converter clutch is not locking. If you are above 45mph in second the converter should stay locked.
Turbo Diesel Dude
Green Mountain, NC
I had an '03 Avalanche that had the so called Towing Package. Found that was ONLY a Hitch/Wiring Harness. NO COOLER other than that small rinky dink one for the power steering. JMHO
charles weidman
