vjstangelo
virginia
Hello all. I am the owner of a 2003 2505 QSS with the rear slide. Last year we had an issue where the top tracks on the slide became detached from the ceiling. We returned it to the dealer not once but twice and this will be the third time (following this last trip) that the same problem has happened. Has anyone else experienced this problem and what was the fix?
Thanks.
goodolejayco
Middlebury, IN
Call or email K-Z. The guy to speak to is Dan Krider. Great guy and will be able to work with your dealer for a solid resolution
lonekazoo
Utah
Ask KZ to send you the small support to place under the slide for traveling. The top slide tracks are really only supposed to be there for guiding the slide in, but large bumps can put enough force on them to cause the few screws to pop out. Many of us have had the problem, but I think some dealers don't know how to fix it properly (mine just put on a couple of washers--if I weren't using the support it would happen again to me).
The support that I use (not the one KZ sends out, but similar) doubles as a barrier to keep our stuff (folding chairs, generator, etc) from sliding around on the floor under the slide.
Good luck!
2005 KZ Frontier 2809PQS-F
2003 GMC Yukon XL 2500 SLT/4x4/8.1L/3.73/Autoride
(Previously 1999 Suburban LT K1500)
1K/10K Equal-i-zer, Prodigy, Champion
vjstangelo
virginia
Wow. Thanks for the quick responses. I'll do both (call Dan Krider and see about getting the travel support).
Can you send a photo of the support you are using? Send to vjstangelo@yahoo.com.
Head'n Out
Wisconsin
KZ has been known to send out the slide support to those who request it. I've heard different stories about the rear slide and what it can and can't support for weight and when it can and can't be used. I would get the support just to be on the safe side. Or you can buy a jack stand from your local automotive store and use that too. Check out the Goin' KZ link in my signature to read about the same problem other KZ owners have experienced.
Dave.
Dave & Sue
Kiley & Emily
'08 Sierra 2500HD Ext Cab/Short Bed 4X4, 6.0L, 4.10
'05 KZ Frontier 2405PQS-F, Goin' KZ!
Equal-i-zer, Barker Hi-Power 3000
Rallies Attended: 11
lonekazoo
Utah
Here's a support that was suggested and tested by a forum member over at GoinKZ (I bought his extra stand):
Camco telescopic stand
If you haven't seen the GoinKZ forum, here's the link:
GoinKZ Forum
cynda
St. Louis, Mo. usa
The day we brought ours home DH grabbed a 2 X 4 and used it for a wedge,we have used that from day one. I just put a pot holder under it. You really don't need anything fancy. People make this way to complicated. I can run out and give you the exact length it was cut if you like before it goes to it's new home. We have never had any problems with the track.
2004 2505QSS Frontier.
