RV.Net Open Roads Forum: Class A Motorhomes: Our entire Aqua Hot failure-fix story
 > Our entire Aqua Hot failure-fix story
beaverthunder
Prince George,BC, Canada
Posted: 08/05/08 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
A few of you may have read my previous posts on our aqua-hot failure.It started to leak from the overflow.eventually all the glycol was gone,replaced with water.The fresh water pump would kick in about every 5 seconds for a split second.I contacted Aqua-hot & was told that it had gotten froze & the fresh water loop inside the glycol tank split.The only repair was to replace the whole unit.I wasn't too happy with that scenario so I pulled out the unit.I took it apart & cut open the tank.I found that the fresh water loop was rubbing against the engine anti-freeze preheat loop & wore a hole thru the fresh line,a definate design flaw.Aqua-hot did nothing as warranty is off.My son in law ,who is a industrial air conditioner tech brazed the lines with high temp silver solder.I then pressure tested those lines.I then got the whole tank welded back up & tested it as well.Back together & back in the coach,everything works as it should.Total cost including the new glycol was under $500.00.This was not a dificult project,no harder than pulling a motor out of car.Anyone with this same issue,contact me,I would be glad to help.
Curtis
2004 Beaver Patriot Thunder Quad slide 505 Cat
No Toad yet
Full timing soon,I hope
v8q
Oviedo, FL
Posted: 08/05/08 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
Great work!
Dave Head
Oviedo FL
95 Foretravel U320C SE
M11, HD4060
brobox
Sunny SW. Florida
Posted: 08/05/08 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
Curtis,
Nice that you offered to help others that may run into the same problem and what the fix was. It is people like you that make this forum great.
Thank you!!
Chuck
02 Travel Supreme, 2 street side slides
02 Jeep Liberty Toad
BigSkyBob
Western Montana
Posted: 08/05/08 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
Fantastic post. This will help others in that position from having to purchase a very costly new unit. Thank you for taking the time to post this fix.
SpinRite
Research Triangle, NC
Posted: 08/05/08 10:25pm Link  |  Quote  |  Print  |  Notify Moderator
beaverthunder wrote:
...not a dificult project, no harder than pulling a motor out of car.
Sounds like your story proves the old maxim:
"You don't have to be rich to own a motorhome.
And you don't have to be mechanically-inclined to own a motorhome.
But, you doggone well have to be one or the other!"
'94 Holiday Rambler Navigator
38', Cummins 8.3 300hp, Allison 3060
pushed by a 2005 Honda Element
Busskipper
Arnold,Md
Posted: 08/06/08 05:56am Link  |  Quote  |  Print  |  Notify Moderator
Good Point.
Also good info on the Hydro-Hot, it's really not that difficult to work on.
Good info,
Busskipper
Maryland/Colorado
Travel Supreme 42DS04
MDX-FMCA--M&G Brake
States traveled in this Coach
JohnnyT
Goshen New York
Posted: 08/07/08 05:20am Link  |  Quote  |  Print  |  Notify Moderator
Great fix! Thanks for posting... Below is a quote from your previous post. Could you share what you did to prevent the problem from happening in the future?
Also what psi cap does your unit have?
Thanks JohnnyT
I have taken the unit out & tore it down.I got the tank cut open this morning & you won't believe what I found.The coils inside are rubbing together because there is nothing holding them appart,ie bracing of somekind,The fresh water coil has rubbed thru on the antifreeze coil from the engine.Its funny because the first time I contacted Aqua-hot on this,the guy on the other end of the phone said the "only way it can leak is it froze."period!! This is definately a design flaw.I will let you know how I make out.Curtis
beaverthunder
Posted: 08/08/08 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Thanks JohnnyT
Hi JohnnyT,I put a piece of hose around the lines where they contacted each other.I am sure this will last for years now.I have a 7lb cap but have noticed others with 13 lb caps,I wonder why the difference.
ole trucker
Westminster,MD. USA
Posted: 08/08/08 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
Good info, Thanks!
Will and Ina's Endeavor
LIVALIL
JohnnyT
Goshen New York
Posted: 08/08/08 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
Curtis, Thanks for the info... My Radiator Cap is 4 PSI... Why the difference is a good question.
Johnny
