helperzack
Port St. Lucie, FL
Got underneath the MH today and I think I found all the places on the front end to grease.
Took a look at the back end and found one spot on each rear brake that looks like a grease fitting, it had a little plastic cap on each.
Can anyone confirm, are there actually grease fittings on the rear breaks, or is this for something entirely different?
I don't want to grease the brakes if not needed, seems that grease and brakes would not really mix, but I guess the caliper may need some?????
As you can tell, I have only enough mechanical knowledge to get myself into trouble.
Any help is greatly appreciated.
’07 Coachmen Mirada 310DS
Counting my blessings with my high school sweetheart.
3 kids, 39 foster kids(not all at once) 2 boys currently
Do you have room for a child? Consider fostering/adopting a child. Thousands of children are in need of a loving family.
SpinRite
Research Triangle, NC
If those fittings are located close to where the hydraulic brake line connects, then you are probably looking at the "bleeder" port, used when purging the lines of air and old brake fluid.
'94 Holiday Rambler Navigator
38', Cummins 8.3 300hp, Allison 3060
pushed by a 2005 Honda Element
othertonka
Stockton, CA
If you have Hydraulic brakes, then those are probably not grease fittings, they are the "Brake Fluid Bleeder valves" used to bleed the brakes. The little plastic covers are to keep the dirt out of the opening. At least that is my interpertation.
I am assuming you have Hydraluic brakes, if you have Air brakes they could be grease fittings. Which brakes do you have? I am not familiar with the Coachman.
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
OnaQuest
Raleigh, NC
What you probably saw was the bleed valve for the brake piston. Do not remove the plastic dust/dirt cover and DO NOT try to grease this fitting. This is not a grease zerk.
I'm not sure what chassis you have, but you may have missed some grease fittings, if it is a Ford, on the drive shaft and/or universal joints.
Dyslexics of the world... UNTIE Visit www.Dyslexics.moc
jerb
phillipsburg, KS
them are bleeder screws used to bleed the brake caliper assuming you have disc brakes on the rear, no grease in there, normally not too much to grease on the rear, just checking the the brake pads and rear end lube is all thats needed in the back!
jimdubya
Paducah, KY
Those are the brake bleeder ports. No grease there. There may be fittings in the u-joints, front, rear, (and center if you have a two piece drive shaft).
2004 Silverado 2500 Crew Cab 4x4 6.0L 3.73
2006 Dutchman Tundra 26RL-DSL
Gale Hawkins
Murray, KY
helperzack
Port St. Lucie, FL
Bleeder valves! That makes sense.
Now the little light in my head has come on. That is what they are, it did not hit me when I was under there. I just didn't think that I should be greasing the brakes.
Many thanks for all the help everyone offered here on the forums. I do learn something new everyday.
My best,
helperzack
wolfe10
But, the caliper SLIDE PINS benefit from being lubed with special high temp grease made specially for this application.
And with hydraulic brakes, change fluid every 2/3 years, particularly in your humid environment.
And when asking chassis related questions, knowing what chassis you have gets you better answers.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
Dogcliff
Anchorage, Alaska
So, hey, all you self maintainers... Just downloaded the Workhorse chassis guide, and found the following maintenance requirement..Quote: Inspect brake caliper slides for corrosion and proper movement, lubricate as required or once per year.
Do all y'all actually pull your wheels and check this? Just curious...
dc
