datawire
Lower Arkansas
Just ordered a double ss sink to replace our plastic one, but it does not have any sound deadening. Anyone ever tried a spray-on or stick-on product that will help with condensation and reduce sound?
Thanks
fordsooperdootydieselsmoker
OrangeCountyCalifornia
You can spray on expanding foam insulation or go to the local car audio place and buy DynaMat.
bldrbuck
Boulder, Colorado
Pick up a can of spray undercoat for under fenders and such. Spray on about 3 coats. It well not get real hard and will deaden the sound.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
Kajtek1
CA
The light foam doesn't make good dampening. Better is heavy stuff like tar. Auto-body shops have special mats for that, or if you know a roofer he might give you a piece of Finlastic type self-stick roofing membrane.
Pessimist sees dark tunnel, optimist sees a light at the end, realist sees lights of coming train.Engineer sees 3 idiots on the tracks.
blucrabbie
Raleigh, NC
Just wondering where you ordered your sink from and what model RV you have? I would love to do this in ours.
New 2 us
02 Winnebago Journey 39QD
08 Honda CRV EXL with Blue OX and US Gear Braking System
FMCA #381833
WIT #W137365
Our Blog
Our MAG1CBUS
hubby and i empty nesters
n4gnn n4hon
I Never Look Back, I'm Not Going That Way!
CHV_FRK
Black Jack, MO
There is an ice shield material for roofing at home depot and the like. Would be very good for what you need. All you really need to do is add mass. As stated foam won't do much good. You can also use the undercoating as mentioned.
Dana and Natalie
2008 Chevy Silverado 3500HD LT DRW CC LB 4x4
2008 Jayco 35RLSA 38'9"
1fastdad
mo.
CHV_FRK wrote: There is an ice shield material for roofing at home depot and the like. Would be very good for what you need. All you really need to do is add mass. As stated foam won't do much good. You can also use the undercoating as mentioned. This is a good suggestion and another one would be the spray on bed liner you can buy in spray cans at your auto parts store.
JFG
TN
Go to an appliance repair facility and ask for the black stick on sound insulation that they put on dishwashers.
Fred
javaseuf
Southern Cal
I just saw an ad for a product designed to do just what you want.
All it is is foam tape. You can purchase rolls of this in 2" widths at Home Depot or Lowes. It's the same stuff we sell here at the HVAC distributor where I work and it's sold for pipe wrap.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
bill h
el segundo
Dynamat works very well. It is designed for vibration damping of metal panels.
Bill and Susan
84 Barth 30 tag powered by ht502/Thorley, Gear Vendors OD
Siamese Calvin and Airedale Hobbes
4WD Toyota toad
