RV.Net Open Roads Forum: Tech Issues: Propane at 10,500' Will it Flow?
 > Propane at 10,500' Will it Flow?
rtate
san marcos Tx
Posted: 08/06/08 06:33am Link  |  Quote  |  Print  |  Notify Moderator
I will be moving to a campground that is about 10500' and woke up this morning wondering if my propane appliances will work ok at that altitude. Anyone had any experience with this?
2005 Dodge Ram SLT CTD 4x2 3.73 auto trans
Arctic Fox 29V
Equalizer 1400lb Hitch
Restless
San Marcos Tx
moparmaga2
Lubbock, Tx
Posted: 08/06/08 06:45am Link  |  Quote  |  Print  |  Notify Moderator
I stayed at 11,700 ft and the propane flowed just fine.
The propane flowing is not the problem, it is whether your appliances have enough oxygen to work properly.
My propane water heater and stove top worked just fine, but my fridge refused to light at much more than 9000 ft on propane.
The Moparmaga guide to cheaply living in a RV while attending College
Moparmaga.com -Trip, Campsite and RV pictures
Camp, Forrest, Camp!
Boise, ID
Posted: 08/06/08 08:20am Link  |  Quote  |  Print  |  Notify Moderator
I wonder if the manufacturer can provide new jets to work at higher altitudes?
-2000 Chevy K3500 CC DRW. 7.4L, Auto, 1985 Lance 900, 1999 Bayliner Capri 1800LS Outboard
-Air Lift bags, Torklift tie-downs, Superhitch w/48", Rancho RS9000X, K&N FIPK, MagnaFlow exhaust, Hypertech.
dobbler98
Ohio
Posted: 08/06/08 09:40am Link  |  Quote  |  Print  |  Notify Moderator
Been as high as 13700 and no propane problems. My fridge always runs on propane and it didn't cause a problem.
1993 Minnie Winnie
Class C 24'
Chevy 350
Usually pulling one of my toys
cm
Dillon, CO USA
Posted: 08/06/08 11:14am Link  |  Quote  |  Print  |  Notify Moderator
In Colorado there are many places at high altitudes that still use propane. Many of the ski areas have ski patrol huts, ski lift attendant buildings, etc., that use propane for their heat source.
At some places, like Arapahoe Basin, 10,500 feet is the elevation of the bottom of the ski area.
NGRRFan
Colo. Spgs., CO
Posted: 08/06/08 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
One thing to have checked is the pressure output of the regulator. If it isn't about 11 inches of water, then I've found that the furnace and water heater don't want to work right.
Rich,and Tobi (the rescued dog)
Prowler 5ver, 84 Ford F250
KCOCOLOR78 Weather
Colo. Spgs. CO
Bubby's RV
CA
Posted: 08/06/08 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Bingo! That's the problem.
You may, or may not, be able to adjust the air flow to correct for altitude, and you will have to correct it again when you get back down. At high altitude, if your appliance lights, the flame may be yellow instead of blue. If you try to adjust it for the high altitude, make sure you mark the shutter's position before you adjust it so you can put it back.
John, Winnebago Minnie 24V
ralphnjoann
Canon City, CO
Posted: 08/06/08 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
Speaking of, I was camping Colorado's high country a couple of weeks ago and I couldn't keep the hot water heater going. I would light the pilot, wait for the thermocouple to heat up, then turn on the main burner which fired up with no problem. Everything seemed OK so I would close the door to go about my other business. After about 30 seconds, the flame would lose power and go out. This happened a couple of times and it finally dawned on me that closing the door was the problem. The burner couldn't get enough air so it quit. I adjusted the air mixture setting and the problem was solved. I suppose I could have just left the door open.
smkettner
Posted: 08/06/08 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
Unless it is colder than 30 below zero the propane will flow. As said above, lack of O2 could be trouble for some items.
Wherever I happen to park
Posted: 08/07/08 11:58am Link  |  Quote  |  Print  |  Notify Moderator
It is not altitude, it's temperature that stops propane from flowing
You may need to re-adjust the air-shutter however at high altitude to allow for the "Thinner" air.
